It has been a while since I've updated anything on this thread, so I guess I should take the time to share some things.
First up, I had some issues with the ARB Twin Compressor being mounted on the MOLLE panel in the SmartCap side bin. The weight of the compressor and the hard hits on the trail caused the panel to fail in multiple spots.
To fix this I had a new, solid 12 gauge steel panel fab'd up. It was a simple one bend L shaped panel that would rest on the bottom of the side bin. I laid out everything for the air system on this new panel and drilled all the mounting holes and then powder coated it satin black.
Using this thicker panel added a lot more weight and I was concerned that the SmartCap side bin would not be up to the task. So, I also had another panel fab'd up to support the weight from underneath and powder coated it..
It looks like it is not aligned with the bin above it, but it is.
With the fridge, dog crate and this support, a lot of the bed space is taken up. At least this support gives me a good place to attach things if I need to in the future.
