Sent DmI will take possession of a new 2023 megacab 2500 in two weeks, one of the options I was after was the factory aux switches, unfortunately, this truck didn't check that box. I was going to order the Mopar auxiliary kit https://www.moparamerica.com/oem-parts/mopar-auxiliary-switch-kit-82216450ab then I stumbled on to this thread. From reading it sounds like this would be somewhat of a waste of money since the truck comes with a PDC, it's just not wired and missing the grey connectors. Is that correct?
also with this kit, it looks like I would be splicing into wires and I prefer not to do that.
@Florotory are you still offering the premade harnesses? I'm sure I could do it with the nice writeup you put together but It sounds like you have had practice..... lol
This can be done, but it’s truly a pain in the ass (it’s been at the bottom of my to do list for the better part of a year). Something no one addresses here is the distinct possibility of warranty claims being denied on the truck. In my case, I’m most concerned about the aux pdc work than anything else. The relays I found came from china, and while not awful, they are sitting in a fuse bank with mopar relays sitting right beside them. The same relays recalled about 3 years ago. So for anyone that hasn’t had the recalls done yet, might be best to do those before you start tearing into your aux pdc and making wiring modifications. That’s just my two cents.
I’m not saying ram will deny any warranty on a post aux switch install, but it’s safe to assume they will. If I was in your seat and about to take possession of a truck that didn’t have them, I’d seriously consider ordering a truck that comes with them. If I was in your seat, I would.
Correct, the relay was for the heater grid relay. Rumors of trucks burning up in driveways with an oem relay is scary enough. lol.
Whether or not a dealer will be able to tell if the aftermarket work was done will depend on the professionalism of the wiring and the potential need to reflash the computer to stock each time you have to take it in.
Great point about the trailer steering.
And I’m not downplaying the ability to upfit the switches. It can be done, and for those of us ‘stuck’ with the trucks that don’t already have them, this thread is a true lifesaver. So thank you all for that. However if I were to purchase the truck now, having installed them, I’d order them next time 100%.
Many thanks to all the contributors to this thread for allowing me and others to install these aftermarket.
Yes 6 gold and 1 male part number CID100-6.3-MS3 from connector ID. If you’re referring to the daisy chain in the PDC.@Florotory
For the jumper harness, it takes six gold female connectors, and one male connector, correct? It seems that the part number indicated for the connection to the relay is a female terminal and not the male terminal, needed for the relay?
68596339AA | Instrument Panel Switch | | | |
68512072AA | Auxiliary Power Distribution Center Kit |
Ram cannot deny a warranty claim unless they can prove that whatever failure they have is due to the modification. The Magnussen Moss act applies.This can be done, but it’s truly a pain in the ass (it’s been at the bottom of my to do list for the better part of a year). Something no one addresses here is the distinct possibility of warranty claims being denied on the truck. In my case, I’m most concerned about the aux pdc work than anything else. The relays I found came from china, and while not awful, they are sitting in a fuse bank with mopar relays sitting right beside them. The same relays recalled about 3 years ago. So for anyone that hasn’t had the recalls done yet, might be best to do those before you start tearing into your aux pdc and making wiring modifications. That’s just my two cents.
I ordered this a while ago from BAM Warehouse and just installed. I still need to activate with AlfaOBD. If I remember correctly when I bought it they asked for my VIN and I got the appropriate switch panel.Researching this for my 2023 2500 Hemi, and I am seeing the following part available as a "kit" that is good for '21 through '23. Any reason why this wouldn't work instead of having to create all of the wiring harnesses myself? It looks like it may just need some of the fuses (possibly moved over from the existing PDC) and then t-taps into the existing wiring harness behind the dash. Only big issue I see is that it appears to come with the switch panel, but there are no options for getting the correct panel for my VIN. Anyone try anything like this? Is there an option somewhere to get it without the switch panel, and just swap in the correct one?
Auxiliary Switch Kit - Mopar (82216450AB)
This is awesome, thank you very much.Here’s all the current aux switches part numbers. 19-21 part numbers have a top row of switches that are glossy:
22+ part numbers have a top row of switches that are matte.
Gas trucks, top row of switches called out, bottom row is 6 aux switches:
Tow/haul, traction control:
19-21: 68476018AB
22+: 68578987AA
Tow/haul, traction control, rear park assist:
19-21: 68476044AB
22+: 68579000AA
Tow/haul, traction control, front and rear park assist:
19-21: 68476024AB
22+: 68578990AA
Air suspension, tow/haul, traction control, front and rear park assist:
19-21: 68476025AB
22+: 68578991AA
Diesel trucks, top row called out, bottom row is 6 aux switches:
Tow/haul, exhaust brake:
19-21: 68376642AE
22+: 68578992AA
Tow/haul, exhaust brake, rear park assist:
19-21: 68476053AB
22+: 68579002AA
Tow/haul, exhaust brake, front and rear park assist:
19-21: 68476031AA (now replaced by 2022 part number)
22+: 68578994AA
Air suspension, tow/haul, exhaust brake, front and rear park assist:
19-21: 68476035AB
22+: 68578995AA
What I ordered (not sure if numbers have changed). Picture is of the switch panel they sent.Good afternoon everyone; Thank you so much for having this forum; it has been awesome. I am stuck in a bit of the same situation...new truck did not have the aux switch but dealer thought it could add without problem. I was and they were confident with the kit available from the VIN / Ram computer catalogue... We are now at 2 kits that came is and still not a match...The issue: My truck has 5 functions on it current panel (2 park sensors, 1 Air susp, 1 traction control and 1 Tow/haul). The Aux switch kits have all arrived without one function. Looking at the part numbers provided by you guys above, it seems it also lacks the features I have. Would you guys have any guidance on proper part number for the issue? Thank you!
Hello, I am finally getting around to sorting out the aux switches as well as the led bed lights. I want to get the Security Gateway Module Bypass, what product are you guys using? From what I have researched there are several ways to go about it. There is the harness from kaodtech https://www.kaodtech.com/product-page/security-module-bypass that connects to canbus blocks up behind the parking brake area (Currently not available). And there is the bypass module from infotainment https://infotainment.com/shop/interior-accessories/obd-genie-programmers/c-modbyp/ that requires the removal of the cluster.
And third one similar to the infotainment https://ecri.app/products/ecri-security-module-bypass-2018-jeep-ram also requires the removal of the cluster.
Also what setting using alfaobd need to be changed to make the aux switches functional? I believe there are two settings?
Any help would be appreciated, this is the nerve-racking part...
Thanks...
