I’m out of my depth here, buT just bought a used 2020 Ram 3500 and it had no upfitter wiring kit. I want to add a radar detector to one of the upfitter switches, but don’t have the jumper wires or the plug that goes in behind the emergency brake. I have a part # (68398184AB), but it appears it’s no longer available. Is your kit a solution?I have 1 harness ready to ship if anyone needs it. If interested just shoot me a message.
The Aux Switches basically gives all of your accessories a central switching panel with an OEM look and location instead of mounting a bunch of aftermarket's switches all over your truck!I'm still a little confused with the whole switches and power thing...
Where do these switches have inputs and outputs to? Like what are they switching?
If they aren't powered, where does power come from?
I appreciate you spelling out pdc ...The Aux Switches basically gives all of your accessories a central switching panel with an OEM look and location instead of mounting a bunch of aftermarket's switches all over your truck!
The aux switches are a set of switches (pictured) that can be wired to any accessory that you choose, through the PDC. For example you can add fog lights, reverse lights, a CB radio, a winch etc. You pick the accessories that you want to control and match them to the correct fuse and control them all through the Aux switch panel, the outputs are in the gray and black plugs mounted to the PDC in the engine compartment.
I have an HD Ram with the Cummins Diesel. Ram includes the Power Distribution Center aka PDC, however I had to add the 6 Switch Aux Panel. After that you will need to make a harness (or buy florotory’s custom harness-Highly recommended!) to control the relays and fuses you install in the PDC. You can also program the aux switches as momentary or latching switches and also program them to remember their last state, so that they remain on if they were last turned on etc.
Hopefully this helps.
From what I can search, we all have a pdc, just not setup for the switches if we didn't order that...
Upfitter package is totally different? That includes the pass through wiring people keep mentioning?
Ok ok so what you're saying is I just need to order the switches and your wiring harness and I'm off to the races?
