I saw a YouTube video that explained this as well. The overhead console does seem to have bat+ , acc, and ground connections in one place.For those with the adaptive cruise and limited/Laramie series overhead console, I got ACC on the large yellow/pink and ground on the large black. For batt power, found the smaller 18 gauge red and black to have batt power.
Do you have the upfitters pigtail that came with your truck? If so, it's essentially pug and play.Because I don't know if I have the connectors for the aux wiring you reference but I'm sure I have an overhead console with all those options.
Not sure, I have aux switches but I'm not using them for the camera. I wonder if trucks wo aux switches still have the pass thru under the dash.I don't have a pigtail... It did come with a random connector but no wires attached to it.
I thought one would have had to specifically order the outfitter module or aux switches?
Are you saying every truck comes with a pigtail to add devices?
They do notNot sure, I have aux switches but I'm not using them for the camera. I wonder if trucks wo aux switches still have the pass thru under the dash.
Which one did you buy for your 2500 since they explicitly state it won't work for HDs?Came here to suggest the Fitcam incase anyone needs one that looks OEM. Doesn’t have some more advanced features but plug and play. Make sure you buy the right model. I have one in my 1500 and 2500 diesel. These are a big hit on the TRX forums.
FITCAMX Dash Cam for 2019 - 2024 RAM 1500 2500 3500
Why You Need This OEM Dash Cam? OEM LookThe dedicated shape of the FITCAMX dash camera is a special shell tailored for your car. Easy To Install Rear cam description:1. Rear cam installation video: 2. The rear camera is connected from the front cam and doesn't need to be connected to the power...fitcamx.com
Ditto on that question.Which one did you buy for your 2500 since they explicitly state it won't work for HDs?
@vandermiWhich one did you buy for your 2500 since they explicitly state it won't work for HDs?
Thats really interesting. Maybe they are out, mine works fine, not sure why they would have changed it, see my order photo below from may. If you’re interested contact them, they answer quickly. Though there is no difference between the two as far as I know (1500 and 2500). They did have a 1500 and a 2500 model when I purchased, so I would double check with them.Which one did you buy for your 2500 since they explicitly state it won't work for HDs?
yep, that’s what I put in my 23 Laramie. Get yourself a Samsung 128gb microsd and format it exfat, or the device will do it for you. That’s about it the rest is plug and play. CarPlay gets in the way of Wi-Fi sometimes but you really don’t need to set anything up after initial install. Really happy with it. Got one for myWell, I ordered the A and it shipped. I will update if the install goes well and works properly in my 2022, Laramie 2500.
Already ordered the MAX Endurance Samsung 128gb MicroSD card. Looking forward to a clean looking dash cam.yep, that’s what I put in my 23 Laramie. Get yourself a Samsung 128gb microsd and format it exfat, or the device will do it for you. That’s about it the rest is plug and play. CarPlay gets in the way of Wi-Fi sometimes but you really don’t need to set anything up after initial install. Really happy with it. Got one for my
wife’s rav 4 after
Same one I use. CoolAlready ordered the MAX Endurance Samsung 128gb MicroSD card. Looking forward to a clean looking dash cam.
