Will_T
I monitor EGT1 and 3. EGT1 so I can know the temp before I shut down the engine. Sometimes when towing, it can be quite high when getting off the highway. I got a bit confused trying to remember what happens to those two temps for caomparison during regen, but now I confirm that EGT3 will spike a lot during a regen while EGT1 stays the same so having that displayed is a good way to know when your truck is in regen.So it seems like EGT1 is just downstream of the turbo, and upstream of the DPF... If I were to pick one of the 5 readings would this be the best overall to monitor? I've also been reading that it is wise to let the engine idle a bit before shutdown to allow the temperatures to cool down and I was thinking that this EGT1 temperature would be a good place to start.
