The CP3 is a radial-piston pump that can supply up to 29,000 psi in some applications and is perhaps the most well known and most modified high-pressure pump on the market.
By far, the easiest pump to access when upgrading or replacing one is those found on inline Cummins engines. Located right on the side of the block, the geardriven CP3s flow slightly less than Duramax-specific units, but volume is still sufficient for making good power.
Next is the CP4, which is also made by Bosch. Although it has a higher number designation, the CP4 actually flows about 20 percent less fuel than its younger brother, the CP3. Found on ’11-to-present Power Stroke and Duramax engines, the CP4 is a more advanced pump despite flowing less fuel, with external high-pressure circuits and a maximum pressure of 29,000 psi.
