bigcitymike
- Joined
- Feb 7, 2020
The lifter/roller clocks or rotates, which is when the whole thing goes kaboom.That lobe is so wide that it most likely will not rotate considering the aggressiveness of the lobe and centerline of the pump. Issue is the design relying on diesel fuel to create the lubricating barrier between the lobe and small diameter roller. I estimate around 5,000 lbf spread on a very small contact area which will result on almost pure metal to metal contact. The forces are no were near the same on a camshaft/roller design which uses a much thicker viscosity oil allowing a protective film between roller (with larger diameter) and lobe. Particles flowing around the inside of that case also contribute to the roller not spinning or sliding on the lobe. Again - piss poor design IMO.
Explained here
