CP4 Changes - to large dimple symmetrical cam version
  • Thread starter Deleted member 80
  • Start date
mostcorey95
Dec 29, 2019
I don't have the large dimple that you mention. And I misspoke, 8 small ones, not 7.
That would be the old style pump. The just released a new style pump that has a new cam in it and no one knows if it will be better. From what my understanding is it’s similar to the can ford is using in theirs and they don’t see as many failures just the pump wears out over time like the cp3 would.
mostcorey95
Dec 29, 2019
I've got the 2 dimple with a January 20 build date. Like the guys say, it's probably just batch differences, hopefully not actual product differences in each batch, that would make for a lot of different scenarios of product description
Yes it’s just a way to track what assembly line it went down and what line it was out on at FCA there are no differences at all with the pumps just away to trace them if they started seeing a lot of one batch be bad but otherwise there is no difference same parts are used nothing is different.
John Jensen
Feb 11, 2020
Bummer! Or, maybe not if the new one is unknown or somewhat known in Fords and maybe doing better.
What a crap shoot.
Then again I shouldn't worry. At my 2-3000 miles a year usage, I'll be long gone before a CP4 failure.
:cool:
Brewbud
Brewmeister Meisterbrew
Aug 21, 2020
SoCal
I assume most of the trucks currently on the lots would have the older style pump without the upper dot. Unfortunately, I doubt they see it as enough of a problem to retrofit those on the lot. I will look if I am looking at a truck on the lot though.
mostcorey95
Dec 29, 2019
It started going it sometime in August so look at build dates of 8/2020 and look at the pump. As of 9/1/2020 they all have the updated pump.
mostcorey95
Dec 29, 2019
What a crap shoot.
:cool:
It’s a pretty ****ty crap shoot to be in if you ask me. The biggest problem will still be water in the fuel. Do you do maintenance yearly or by mileage?
John Jensen
Feb 11, 2020
I maintain on a yearly basis. Neither of my two trucks or my Jeep exceeds 5000 miles a year. In fact, two years ago my rock crawling Jeep was zero miles.
Rich
Banned Member
Feb 3, 2020
Not to panic but I've read some articles that some of the cp4 failures have also happened at any early millage marker. Doesn't seem to matter what the millage. If we get some iffy fuel, it can really do some damage quick
John Jensen
Feb 11, 2020
Yeah, I've read that too. Seems like there's no pattern other than poor lubricity fuel, contaminated fuel, or water contamination. That's why I always have and always will use additives as preventative maintenance
Rich
Banned Member
Feb 3, 2020
Same here. I'm just going to switch from the crappy howes to the hot shot to get maximum lubricity
mostcorey95
Dec 29, 2019
I checked my pump and Yayyyyy! it has a single dimple. :cool:
That is if I ignore the other 3.
Yes you want the dimple that’s higher up and the low dimples don’t matter it’s just what line and what batch it is from like I have stated before.
Rich
Banned Member
Feb 3, 2020
Is this the Hot Shots you are switching to? I read the other thread and was getting confused.
Hot Shots EDT
Yup I'm going to switch to the hot shot. I'm waiting for them to get back with me and tell me if the lx4 wich increases lubricity by up to 56% is the same as the edt with lx4 in the ingredients, I'm assuming not the same percentage but I'm waiting to find out as I don't want the multi vitamin with a little bit of everything in it, I want the one with the most lubricity. So we dont get in trouble by the thread police (lol :p ), we should probably keep it on the other thread for the sake of argumentation. ;):cool:
carlrx7
Oct 20, 2019
This is for the Cab & Chassis w/ Cummins engine. I posted it because it details the pump identification marks.
5 Associated Documents
Just thought I would add some clarity if needed. This is the way I interpret the current state.
There is no current CP4 pump recall. The W57 recall is for software tuning (warmup protection changes) on the C&C trucks only. These trucks run a different tune than SO or HO pickup engines. That W57 recall also includes the tech instructions for using the correct flash depending on which style pump is installed.
