narrow gauge 804
Considering a cold air intake system by BS.
Doing so will the factory warrantly be VOIDED ?
That said CANADA DOES NOT HAVE A NATIONAL ACT AS SUCH, BUT EACH PROVINCE HAS SOME SOME FORM OF LEGISTRATION WEAK OR STRONG DEPENDING ON WHICH PROVINCE OR TERRITORY LOCATION.No need to shout. Your posts never mentioned you were in Canada, you don't have your location visible, and don't have it in your signature.
I don't have any first-hand information, just have heard from quite a few Canadians back in my FJ days, but what I recall is that there are similar provisions within the Consumer Protection Act, but that each province has a slightly different take on what all is protected. That said, if I were in your shoes, I am doubly certain that I wouldn't be adding a CAI.
Decided against doing so.Don’t waste your money, you’re not going to get much better flow and cold air than what the factory gave you and you will definitely get less filtration.
You forgot to mention decreased filtrationThe only thing these intakes give on either platform is increased noise (sound) from the removal of Hemholtz style resonators put there by OEM to reduce NVH. Under stock tuning that engine isn't close to being able to max out the airflow potential of a stock intake setup. Beyond that, many aftermarket intakes just turn out to be HAIs (hot air intakes) exposing the filter to the engine bay heat or using metal heat soaking box material. IATs suffer as well as performance as the engine pulls back timing to prevent detonation.
All that, and the dirt stopping ability of a window screen.While I don't disagree with everyone here, I noticed K&N just released their CAI for the new gen Ram 6.4L and claiming an increase of
14.94hp @ 5495rpm
21.34lbft @ 2503rpm
Dyno'd to the wheels... which to me is a decent number, thoughts? You know before I "waste" my money on one?
Cold Air Intake - High-flow, Aluminum Tube - RAM 2500/3500 V8-6.4L
PERF. INTAKE KIT; RAM 2500/3500 V8-6.4L F/I, 2019-2022www.knfilters.com
