Ramit530
Found it. Thank you so much good sirIt’s still there for me. Are you sure it’s not under the suspension controls or the apps screen?
This is a little off topic but does anyone know why the new Ram 3500 do not have a rear anti sway bar. Plan on doing some camping with a truck camper. Can't imagine driving our mountain and coastal roads without one.For those that have the air suspension, there is a new “Bed lowering mode” that can be used to drop the rear end by 3 inches. The alternate trailer height drops the rear by 1 - 1.5 inches.
To access the bed lowering mode, you have to go into Apps on your Uconnect screen, scroll over until you find the icon labeled “Bed lowering”. This button is not available anywhere else. You can drag it to your menu bar as I did and replaced my climate button as it’s redundant.
Once pressed, the 7” cluster screen will indicate its lowering the bed and drop the bed 3”. It will indicate “bed low”. The bed will raise again until normal height is achieved if the vehicle moves over 25 mph.
This is very handy if your trailer needs a drop greater than the alternate trailer height can allow for your hitch ball to separate from the trailer tongue.
It’s not really documented very well on the inter web nor in the manual clearly stating that the bed lowering button will completely drop the bed beyond the alternate trailer height. Figured it will save someone the research.
Enjoy!
Hi all,
Has anyone heard of getting this feature turned on or implemented in the 1500's with air suspension?
Yeah but my wife might get mad if that’s what I was using the bed lowering feature for!Seems like it would be very handy option to have if the tailgate is just a little too high to bend your girlfriend over
I have only had my 3500 for 2 weeks and it’s been cold in Ohio so I haven’t played with it much but today I measured the rear wheel well. Hit the bed lowering button. The dash said “lowering” but it definitely didn’t go anywhere. I’m anxious to get my travel trailer hooked up to it and use the Alt Trailer feature but honestly I’m struggling to find a lot of info on how that works.
Just picked up my 3500 with the air suspension yesterday. The Bed Lowering function is not even listed in my display options. Did they just do away with the bed lowering function on the 3500's with all the confusion I have read about as to whether or not it even works on 3500's?
Nope, only thing in there is tire jack mode, transport mode, and wheel alignment. No bed lowering. I wonder if they removed it on the 3500 option programming as from what I gather it didn't work on the 3500s anyways?Nothing under the Suspension option in settings?
Mine worked as expected, about one inch.Nope, only thing in there is tire jack mode, transport mode, and wheel alignment. No bed lowering. I wonder if they removed it on the 3500 option programming as from what I gather it didn't work on the 3500s anyways?
What year is yours?? I forgot to mention, mine is a 2021Mine worked as expected, about one inch.
Yeah sorry, I'm just on my Google browser on my phone, I don't see any sig lines on any posts ?2020
Assuming you're on tapatalk and can't see the sig line.
My 3500 is the same. The system is working properly, ram just did a piss poor job of informing the 3500 owners how the system works.My 3500 has to have more than 800 pounds in the bed to get the lowering option to work.
Well I got like 3/16" of an inch lolFinally found the bed lowering function on my 2021, it was not listed in suspension settings, I actually found it in the apps screen. I'll have to measure later when I get home and see how much it drops.
