Bed lowering mode details
Omarf4
Jul 2, 2019
For those that have the air suspension, there is a new “Bed lowering mode” that can be used to drop the rear end by 3 inches. The alternate trailer height drops the rear by 1 - 1.5 inches.
To access the bed lowering mode, you have to go into Apps on your Uconnect screen, scroll over until you find the icon labeled “Bed lowering”. This button is not available anywhere else. You can drag it to your menu bar as I did and replaced my climate button as it’s redundant.
Once pressed, the 7” cluster screen will indicate its lowering the bed and drop the bed 3”. It will indicate “bed low”. The bed will raise again until normal height is achieved if the vehicle moves over 25 mph.
This is very handy if your trailer needs a drop greater than the alternate trailer height can allow for your hitch ball to separate from the trailer tongue.
It’s not really documented very well on the inter web nor in the manual clearly stating that the bed lowering button will completely drop the bed beyond the alternate trailer height. Figured it will save someone the research.
Enjoy!
Zinga
Jun 13, 2019
The manual also states this:
Most 3500 models will not lower to Alternate Trailer Height (ATH) when unloaded.
This is in reference to lowering only 1". If the 3500 won't lower 1", I doubt it'll lower 3".
thestuarts
Jun 10, 2019
I think @Omarf4 is saying there is a difference between the alternate trailer height mode and the bed lowering mode. I will try this tomorrow and let you know if it works. I hope it does, because my truck is 1/2" too tall to fit in my garage at work.
jpaeth
Feb 18, 2019
Even if it does lower the bed, it will only be dropping the rear of the truck, not the cab. You will still be too tall. And the 3500 wont drop at all without a load on it.
Distillusion
Jul 23, 2019
If you lower the body at the rear axle, the center between the axles will drop about 1/2 of that. That's about the center of the cab. The front of the cab is about 1/4th of the distance behind the front axle, so it will lower maybe 1/4th of what you lower the rear.
thestuarts
Jun 10, 2019
Thanks. That's good to know. I will give it a try with some sand bags in the back just to see if it gives me the 1/2" extra clearance I need.
jpaeth
Feb 18, 2019
Well, the highest part of the cab is the front, with the antenna there, which is the part of the cab that will drop the least. I know what you are saying in that if you drop the rear the angle changes and will drop the cab, my point is that it will be such an insignificant drop that it probably won't be noticeable. And on my truck, if I am looking at clearances of fractions of an inch, I'm not even trying to fit it in that space.
Distillusion
Jul 23, 2019
[/QU
Yep, if the bed lowering mode only goes for 1 inch, you'd only get 1/4" at the antenna. And that's exactly why I answered the way I did. But for the folks that can make it in the garage but are nervously close, dropping the bed 3" means the antenna should drop around 3/4 of an inch, perhaps increasing their comfort level a bit. Doesn't really matter to me, either. I won't have a truck that won't fit in my garage without lowering. Because eventually I'd forget to lower it while driving in in the dark or something.
thestuarts
Jun 10, 2019
You are right that it is risky to lower the bed to get into a garage. I could forget to lower the bed, or there could be an unexpected low spot. In my particular case, the lowest spot is just the main gate, so once I get past the gate I don't have to worry about the height.
With the bed lowered, I was able to get into the garage this morning without touching the 6'6" warning sign. Now I have to decide if I want to go lower the bed every morning and worry about forgetting when sleep deprived.
Ramit530
Apr 29, 2019
Pennsylvania
Enjoy!
I know you mentioned it raises back up at 25 MPH, mine raises the moment the truck starts to roll using the accelerator, as well as the button grey's out disabling it...
thestuarts
Jun 10, 2019
Thismorning I noticed mine also raises back up when the truck starts to roll.
evanyj350
Aug 19, 2019
This is the best news yet. It fixes my only disappointment with my 2016 rig. I hook up bumper pull trailers almost daily and use the rear air suspension to help. I go thru the settings menu to get to "Transport Mode" but it takes about 5 steps to get there. I am so excited they put an icon on the screen for this. They should really have a button at the rear bumper or on the Fob for this in addition. I am a huge fan of the rear air suspension on the 2500s. Self leveling and hooking up a trailer, it is amazing ! I plan to trade my rig in when the 2020s come out.
MoneyMagicMike
Sep 10, 2019
Does
anyone know if it work at all unloaded..my truck does not budge a peep on flat ground up or down
MoneyMagicMike
Sep 10, 2019
I’m wondering if my system just doesn’t work on my 3500 limited new house payment anyone no what to do to get it working...dealer said two weeks then would need overnight just to get in rotation to peek at...I’m sad...5 day old truck.....everything else with it is superb...probably just wait till someone else finds a fix if it’s something simple...here’s to hope, cheers
Don-T
Feb 4, 2019
My 3500 has to have more than 800 pounds in the bed to get the lowering option to work.
Ramit530
Apr 29, 2019
Pennsylvania
Yesterday went to hook up to trailer and noticed my Icon for “Bed Lowering “ is gone. I have used this function in the past and it’s a great option but now can not find it any where. I know I have received a few U connect updates and wonder did they remove this option?
Omarf4 or anyone else check and see if they still have it, and share where to find it again?
geektoad
Feb 21, 2020
when I went through everything when I first got my 2020, i never saw that icon in the apps. I'd assume they removed it
Ramit530
Apr 29, 2019
Pennsylvania
Well that’s a BS way of fixing a select few vehicle issues. They advertised the hell out that feature when they rolled these trucks out and now it’s gone? And the fact they don’t tell you is even more BS. I am hopeful there is a way yet to do it, it is a great feature.
Omarf4
Jul 2, 2019
It’s still there for me. Are you sure it’s not under the suspension controls or the apps screen?
geektoad
Feb 21, 2020
I double checked this morning and it is indeed there, and works.
