Okay I hope that I can help and explain this right seems to be a bit of confusion on here about adding aux switches. Yes it can be done with time patients and some time.
Okay first can you buy aux switches plug and play no if your vehicle did not come with it then it’s not wired for it.
Second make a plan I will share mine with you and I’m not saying this is right for everyone or you have to get this but this is just simply what I went with. This is why there are options out there and choices but the choice is yours to make on how you want to execute your plan.
Okay so I started off as you might have searching google and finding very little info or knowledge luckily I stumbled onto this post and it gave me the drive to execute this as I wander the stock factory feeling of the aux switches.
Third I will attach pictures of my invoices and the tools needed for extra guidance.
Okay supplies.
-To run the aux wires I wanted the stock like setup felt like this would be nice so I went to wirecare.com and ordered the connectors.
-Relay box concours specialties has a 6 fuse and 6 relay water tight build. (find on Amazon)
-ObdLinkMX+ (Find on Amazon) you can get the cheaper one I prefer the Bluetooth and wireless
-AlphaOBD to program the truck with the aux switches, okay so they have a windows version and android I bought windows and it sucked went with the android was a lot more user friendly and cheaper. (Google play store)
- Security bypass harness (Zautomotive.com)
-aux switches you can find them in multiple places but keep in mind there are a lot of options like air suspension, exhaust brake, tow haul, parking sensors, etc. so find one that matches up with you like mine I have the diesel the tow haul and exhaust brake are switches around on the one with the aux switches however they function as they should.
Tools needed
-8mm socket
- drill with drill bits
-closed barrel wire crimper
-soldering iron
-heat shrink tubing
-16 awg wire (<5’ runs x 6)
-wiring loom
- torxs bit
First I removed my radio I have the 12” Uconnect myself screws located at the top the. You feel like your about to destroy your truck as the rest is clipped in and you tug and you pull and you freak out because you feel like you just broke something. Take your time it does require you to pull with some force to get it to come out.
Okay once out look where your toggle switches or blank is/are and remove the torx screws and pry the clips and replace with new one and put it all back together we are done here.
At this point I played with alphaOBD finally got it to work on android platform better than the windows and found under instrument panel you can enable the 3-6 aux switches and for me to adjust them it’s not through the radio it’s on my 7” gauge cluster under commercial settings. Default pin is 0000 then you can set them up to run off ignition, or constant battery, momentarily, or latching, and the last state they were on or off.
Okay the hard part so once you decide on your relay box weather you want to build the factory harness or go after market under the steering column remove the 2 8mm bolts get the panel out of the way. The harness that I have a pic of you will any to access the little brown wires could CAUTION ⚠️ COULD POTENTIALLY BE DIFFERENT IN YOUR VEHICLE. Okay so this plug you do not want to mess this up it pretty much controls your vehicle I suggest to get a volt meter to verify I just did a simple conductivity test (the sweating in OHMs that beeps) as the aux switches use ground as the relay trigger wire less potential for fire and over loading the switch itself, (pin out description attached in photos) for my self I cut them flush at the plug pins 34 (Aux 3), 36 (aux 5), 37 (aux 1), 38 (aux 2), 40 (aux 4), and 41 (aux 6) now keep in mind I did verify each one of these with a meter to ensure the were the right ones before cutting them. They will be all brown wires with green, purple, black, white, grey stripes and one tan colored one was aux 5 I believe. So I cut these bad boys and then I stripped the wires soldering the ends and then I drilled a hole through the plastic circle to the left of the brake pedal on the fire wall. And I feed my six color wires out I bought the 16 gauge and 12 gauge wires to match so I could color code my aux switches. I solder them to get her and heat shrink the connections. While your down here you can access the BCM (body control module) and add in you security bypass harness if you haven’t already done so yet.
Under the hood
Okay your wiring up your relays if you bought the one like mine you will have to cut and separate the ground wires as these will now become your trigger wire them up with the ones you ran through the fire wall from the aux switches the trigger wires that are the smaller wire will now tie together and be come positive with your accessory positive lead connect to battery and for your power to accessories the stuff you got like me you will crimp your wire to the corresponding connectors.
