elephantrider
Hydraulic Lifter Crew
- Joined
- Sep 3, 2019
Thanks to all. We got the key on relay wired and working. Currently we have a dumb no light toggle switch completing the ground.
https://www.amazon.com/dp/B071H9KWL...abc_D180XXY7FTZNKWW9M6VH?_encoding=UTF8&psc=1
Is it possible to wire this switch on a switched ground so that the led comes on when the switch is pressed? I'm thinking the switch will work to complete the ground, but tying led power into it will have the led on, then when pressed the led will turn off, opposite of what we want.
That’s very informative. Thanks for doing this video.Hi All,
I've been reading and rereading this thread for a while and wanted to save my input until after I finished adding the Aux switches to try and make everything a little easier to understand. A huge thank you to member Atty who was great at helping me answer a few questions I had at the get go. I put together the following video and loaded it to my YouTube channel for anyone who wants to follow along on what I did. I included the part numbers for most everything I could think of in the description of the video - hope this helps!
If you have any questions for me on what I did, feel free to shoot me a message.
I also forgot to mention prices for the whole install. The breakdown for everything I purchased is detailed in the description of the video. All up, it cost about $370.Hi All,
Based on the table below I need part 68376644 but the website I am looking at says doesn't fit my 2021. Anyone use this part on a 2021?
Thank you
When the website that you're purchasing from is comparing the number it is comparing it against what your vehicle features were when it was sold. Therefor because your vehicle wasn't equipped with the Aux switches it will say it doesn't fit your model. Before this table was found/created the only way to get a part number for an item you wanted to upgrade was to find a vehicle that was the same year/model/level that had the features and look up the switch part number from the vehicle using it's VIN. Maybe if you really want to compare to make sure that the number is correct for you, is to find a vehicle for sale (online) that is the same year/make/model get it's VIN and use that one on the website that you're looking at purchasing through? Or using the table look up the part number for what's in your truck and see what the website says about "fitting" it should confirm that the one in your truck is the same as what is in the table.
#38 and #42 appear to have the same marks.I don't see that this was posted anywhere, and it's always best to find a truck VIN with AUX matching your other features, but this AUX switch decoder chart was seen on the sister site 5thgenrams. I don't know the true source, use at your own risk.
I think #42 is correct and #38 should be on traction control and not on Exhaust brake.
Them Mopar graphics are so poor I ordered #38 and assumed it was the one I needed according to the chart.
elephantrider posted a picture of what it suppose to be. He knows the proper part#.It appears so. I didn't make the chart, just found it online.
Good info if you have something that shows the panel, I can make note of it.
I'm all in. Like the factory setup and all but man a 6 shooter BT setup allows for hidden switches, phone app, no wires ran into the cab and for like 300$
Has any body accessed the Aux wirea from the XY125A connector?Also, if the six aux switch wires are already populated on the connector that plugs into the switch bank, then their next stop is the xy125 connector at the driver side footwell-
thanks!I got the wiring kit from paul. once you have that, and install, alfa will allow changes to activate the buttons.
Whos Paul?I got the wiring kit from paul. once you have that, and install, alfa will allow changes to activate the buttons.
