Anyone have the 2019-2020 trailer camera yet?
Crap. FCA could fix that with programming but I doubt they will.
Agree, very very disappointed.
GM has an invisible trailer in their solution and we can't even get a constant on observation camera.
You know, even if the camera came on when the turn signal was activated, it would be an added safety measure. Particularly since the blind spot detection doesn't work towing a fifth wheel.
The only hope is the aftermarket comes out with a black box, similar to what is already available for Ford's surround camera system, that allows one to keep the cameras constant on.
lovegolf44
Feb 4, 2020
You think the trailer cam setting (viewable anytime) could be changed through AlfaOBD? Just thinking out loud here, seems it can do just about anything else.
Seems none of the radio/Uconnection functions can be altered by AlphaOBD.
I think the only hope is the aftermarket.
Rich
Banned Member
Feb 3, 2020
I could deal with the Crap $500 camera pkg if we could all just figure out a way for it to stay on while traveling. That was a really stupid over look
1FastHemi
Jan 4, 2020
Would this work? https://www.coastaletech.com/uconnectairv2.htm I had v.5 in my 2009 1500 and could use the backup cam anytime.
I used Lock Pick on a 2010 Challenger SRT to add a Front and Rear camera and worked out great. Once I got it all setup, I haven't even thought of that company until I saw your post. It's now 2020 and the camera system on the OEM stereo is still working great.
Rich
Banned Member
Feb 3, 2020
Looks like it would work out great, just not interested in to spending $500
That wasn't available when I started looking.
They don't list anything for the 12" or I might consider if:
1. It works with the 12"
2. It keeps working through updates*
3. Camera in motion worked with factory cams
NOTE: CHRYSLER HAS CHANGED THE SOFTWARE FOR RECENT PRODUCTION RAM AND GRAND CHEROKEE VEHICLES SO THAT THE FACTORY REAR CAMERA IS NOT ACTIVE AT SPEEDS ABOVE 10 MPH. THE LOCKPICK CANNOT ACTIVATE THIS CAMERA WHILE IN DRIVE ABOVE 10 MPH HOWEVER, ANY AFTERMARKET CAMERA CAN BE ACTIVATED REGARDLESS OF SPEED.
I still think it is just utterly stupid that GM has an invisible trailer camera system and FCA/RAM won't even enable the Aux trailer camera in-motion capability. In fact, I'm really pissed off it doesn't as I did plenty of research before spending money on the option that in the end, is probably going to be useless for my needs.
Rich
Banned Member
Feb 3, 2020
Im right there with yah, that's the sole reason I purchased the new technology. All that an ill probably just end up sticking my plug in furrion in there, wich was what I was trying to get away from, a bunch of do dad's, was trying to keep a clean look.
My issue with furrion is that the vertical viewing angle is crap. I want a quality Sony UCCD with a 90* vertical view for my observation (primary) and backup (secondary) use.
Rich
Banned Member
Feb 3, 2020
yeah, I've got one picked out an saved in my cart to. I'm just starting to get pi$$ed off an fed up about every thread that pops up has something to do with something being missing or not aligned An quality what they were expecting. I mean lm glad everybody posts so we no whay to look out for but dam is it that bad out there . When I bought this 16 2500 new off the lot , i didn't have one thing I had to complain about our I wasn't satisfied with. Ouf coarse back then I wasn't as knowledgeable on all this stuff. Knowledge is a double edge sword.
I was asked for the part numbers of the Bed components on the 2020 XFQ wiring setuo.
For anyone that added the XFQ and got only the bumper connection, or already has it in a 2019, here's some pics of the 2020 setup in the bed.
I can't say if this is everything, but it's the housing and cable parts down to the chassis connections below. The Aux camera wiring harness on my 2020 is plugged in form bed to chassis harness. the bumper Aux camera cable is capped with a dust plug.
I did not measure the two different cables so I don't know if the bumper cable will reach to the bed location. It appears to be shorter but I'm not going to cut all my tie wraps to find out. Maybe I'll put a tape on it if I think about it, but perhaps someone with the bed cable self-install kit can check too.
68445096AB Bed 12-pin cable (zero hits on search)
68453200AA (only getting one hit on google search)
68398007AA 7-pin bed cable (should have this) I see 68398006aa listed for 2019 models
Pic I've posted before of Aux cam connections behind the license plate.
68445095AB 12-pin Bumper cable
Rich
Banned Member
Feb 3, 2020
For anyone that added the XFQ and got only the bumper connection, here's some pics of the 2020 setup in the bed.
Nice pics, good to know on the bumper dust plug
D
Deleted member 80
Guest
Yeah, the whole tech thing is a bust for my purposes. I love the new headlights, and the improved cooling system, but if I had it to do over, I would have bought an '18 leftover, saved some $$$, and avoided the CP4, hollow camshaft, scissor gear, hydraulic roller lifters, and low friction piston/ring package.
Rich
Banned Member
Feb 3, 2020
I just know after i spend the 550 on that camera system I'm going to be p.o.an throw the furrion one in the cup holders or wire it into the aux switch bank. Just hate that i spent the money for the aux capability an there system won't stay on. I wish I knew that when I sent my paper work in for build. Should of never assumed
1FastHemi
Jan 4, 2020
I think LockPick has a unit to help with that among other features. Has anyone check with them lately to see if they have the 2020 year with 12 screen available yet?
Phil T
Jun 3, 2019
Thanks for the pictures of the 2020. My 2019 rear wiring does not have any provision to have the trailer cam in that location. I suppose you could cut the hole that shape and swing the bumper connector for the camera to that hole. I added XFQ myself
and it runs right under that area. In fact, the 7way comes up from the main harness. The hole is round, so there is no way to put that new plate there unless you cut the bed. There are only two mounting holes for the 2019 also.
thestuarts
Jun 10, 2019
My 2019 XFQ camera plug is in the bumper. From your pictures and description, it seems like I could use the 2020 parts to add a camera connector to the bed, although I could only use one of the camera connections at a time. Is that your assessment of the wiring?
Phil T
Jun 3, 2019
See my post above. I cover what you would probably need to do.
