Aftermarket Wheels and Tires - post yours
NightTrain
Jan 17, 2022
Boston
I love the looks of the 1 offset, tires stick out around 2 inches past the stock fender flares which gives it a good stance without over doing it. The shop cut off a few inches from the wheel liner so I assumed it rubbed there but it doesn’t rub anymore even at full turn.
Thanks, appreciate the photos
NightTrain
Jan 17, 2022
Boston
These just came in - 20x9 20mm. Will wait til spring before I buy tires and throw them on. I can’t decide between 35 or 37’s. Ordered truck with 3:73 because I swore it was going to stay stock but now wish I had 4:10’s. I know a lot of people are running 37’s with the same gearing I have but I’m already downshifting a lot on the highway as it is.
aaronedmonton
Sep 5, 2021
I’d go 35s at the most. I went 35s with my 3.73 but didn’t really like how sluggish the truck felt. Went back to stock. If you had a diesel then I would say 37s could still work.
phrogman
Jul 23, 2022
I have 3.73 gears and 35 inch tires. It rides fine, I did not notice any power loss or additional downshifts. Nice pick on the wheels, I have the Coverts in bronze.
Crusty old shellback
Apr 10, 2021
Not aftermarket. Stock Power Wagon Bead lock rims.
I painted them using dip your car paints.
I used wicked wine and gloss clear for the rings and bronze gold hyperdip for the rim.
BFG 35x12.50 17s
Haynz
Jun 19, 2021
2021 RAM 2500
Nitto Ridge Grapplers 33” 12 ply
Fuel Siege wheels 20” -18 offset
Stock suspension
Jimmy Dean
Apr 26, 2021
NJ
2022 Tradesman
Carli 2.5” Leveling Kit w/ Fox 2.0 Shocks
37x13.50x20 Venom Power Terra Hunter X/T (GARBAGE DO NOT BUY, BEING WARRANTIED FOR OUT OF ROUND, NOT WORTH ANY SAVINGS $800 later)
Method 301 20x9 +18mm offset
Trimmed plastic only and now no rub at full lock.
neutroniens
Jul 5, 2020
255/80R17 Falken Wildpeak at3w on 17x6.5 Ultra Wheel 003 Hunter Truck Dually with inner OEM Ford steel 17x6.5 wheels (same manufacture as Ram OEM steel wheels)
Dpettina69
Dec 3, 2022
35/12.50RBFG KO2s. XD820 wheels. 18x9 +18 offset
Jimmy Dean
Apr 26, 2021
NJ
2022 Tradesman
Updated Mickey Thompson Baja Boss ATS
37x13.50R20
Sits about an inch higher, closer to true 37.
Still no rubbing with only plastic trimmed.
TroyMcClure
Nov 2, 2021
British Columbia
295/65R20 Toyo Open Country A/T III tire on the stock Night Edition wheels. This is a 2022 3500 HO Cummins Mega Cab Limited with the optional air assist. There is no rubbing to speak of on this combo. The optional air assist and a skinnier tire being the key I think. Stoked it's not as wide as a 35x12.5 to bite the snow a bit better.
PCT
Apr 8, 2020
Bilstien 2inch coil lift, 5100 all corners. Tradesman with power wagon pull offs on 35 at3xlt
Brewbud
Brewmeister Meisterbrew
Aug 21, 2020
SoCal
how many inches of lift did you need to run 37s
It is more about the wheel specs offset and width than the lift. I went weeks with 37s and no lift. I did trim the pinch weld and liner a bit but I had to do that for the lift anyway. When you compress/flex the suspension you get that tire to the same spot as it would be on a stock suspension. Unless you run lower bumpstops which you don't want to do. The lift pictured is a 3-1/4".
