Aftermarket Wheels and Tires - post yours
408MegaCab
Oct 19, 2021
Method HD NV 305 - 18x9, +18 offset)
Toyo Open Country R/T - 37x12.5x18
Thuren 2.75" Leveling kit w/Fox 2.0 IFP
99mo
Feb 7, 2022
Missouri
Wholeo
May 12, 2022
Nice Ram !!! Thats the look I'm after and looking at the 2.75" Thuren on my Mega Cab. Did you do anything in the back and is your truck level or nose high ?
eljefe
Oct 22, 2021
Here is my current set up. I plasti dip the steel wheels and upgraded to a set of 286/70/17. Decided today thought to upgrade to a set of 20" Black Rhino Armory Sand Color with a set of 285/60/20 Toyo AT, even splurged to get a matching spare. Didn't want to change the factory suspension because I wanted to keep the 5th wheel set up. Will post up when they are installed.
phrogman
Jul 23, 2022
Fuel Coverts 20x9 Nitto Recon Grapplers 35x11.5
sootrat
May 26, 2022
Rough Country. The kit is for a 1500 and doesn't work with a 2500 grill. I fabricated my own mount to stabilize the lights in the grill.
Have any additional photos of the grill lights? Any mounting suggestions? Will i need to cut the grill?
Thanks!
brodon
Jul 7, 2020
This truck is gone but this was on methods with factory crap tires.
NightTrain
Jan 17, 2022
Boston
Fuel Vapor 20 x 9 plus 1 offset on 37 x 12.5 20 Nitto Ridge Grappler
How do you like that offset? Any trimming needed?
I wanted to drop down to a 18" Fuel Covert to improve the ride a bit but, in 18" they only make it with a 1mm offset. I wanted between 18-23" offset but, will need to go up to the 20" wheel for that - at $100 more per wheel.
Enve46
Jul 20, 2021
Finally something for us guys that like shiny stuff.
You said you like shiny stuff? 22x10 Fuel Forged FF09s, 325/50 Recons. Some plastic trimming and pinch weld massaging. Floating that fine line of a brodozer, I know. Got tired of all the black murdered out trucks rolling around, wanted to stand out without going overboard.
Chriss626
Jan 1, 2022
I love the looks of the 1 offset, tires stick out around 2 inches past the stock fender flares which gives it a good stance without over doing it. The shop cut off a few inches from the wheel liner so I assumed it rubbed there but it doesn’t rub anymore even at full turn.
