Aftermarket Muffler?
MikeStang
May 10, 2019
2019 Ram 2500 Gas burner here.
Has anyone swapped out the enormous muffler on one of these beasts yet?
Would like a direct fit muffler if anyone has suggestions?
Also what about the big ass resonator at the end by the exhaust tip, do you remove or leave that thing?
Gondul
Prince of Pintops
Mar 10, 2019
I think @hutchman may have swapped out his muffler.... I'm considering contacting B2 Fabrication to see if they can come up with something
B2 Fabrication
MikeStang
May 10, 2019
Keep me informed, bc I really dont want to go let a muffler shop hack and slash my exhaust, would much rather a bolt on deal I can do at home
Gondul
Prince of Pintops
Mar 10, 2019
hutchman
Mar 12, 2019
I had a Magnaflow installed and the resonator removed. The Magnaflow is a straight through style muffler and it is loud without the resonator. The noise level is OK for now, but if I tow in the future, I might look for something less throaty!
Gondul
Prince of Pintops
Mar 10, 2019
B2 Fabrication does not have anything for the 2500s...
I sent a message to Mufflex to see which Magnaflow muffler they use.
Gondul
Prince of Pintops
Mar 10, 2019
Looks like the OEM muffler is simply clamped on either end so it should be a simple operation to replace... getting the new hangers on would be the 'issue'...
hutchman
Mar 12, 2019
FWIW, the Magnaflow on mine is "throaty." My fear is that when towing, it might be too "throaty!"
Just be aware...
Gondul
Prince of Pintops
Mar 10, 2019
Which one did you get? The 14" version?
huff2462
May 12, 2019
Severn, MD
I have an 18" Magnaflow 12278 (not Mufflex) on my '13 1500 with the 5.7l. It sounds great, and not obnoxiously loud at all (though my wife would disagree). I don't plan to add one to my 2500 when it comes.
For what it's worth, the Mufflex are designed to be a simple DIY install in a driveway (no welding or cutting) BUT... they're more prone to rusting than the standalone Magnaflow mufflers since the Mufflex's don't get the same coating from the factory.
I ended up saving money ordering the muffler and paying a shop to install it.
hutchman
Mar 12, 2019
Mufflex uses the 14" Magnaflow 4" ROUND STRAIGHT THROUGH exhaust.
It looks like Mufflex is the only game in town... I am not aware of any other vendor selling a 'bolt on' exhaust...
Just noticed this.....mine is oval, center in/offset out. It's the same one I had on my 2016, which I toughtbordered on being too loud also. But, in addition to the muffler, I had the resonator removed too. That probably has some effect on mine being somewhat loud.
But loud is certainly subjective and what is loud to me might not be to you.
hutchman
Mar 12, 2019
This is the muffler I put on my 2016:
However, on my new one, the muffler shop installed one and I'm not certain how long it is thinking back. If my back allows, I'll measure it tonight.
Gondul
Prince of Pintops
Mar 10, 2019
For what it is worth, the body length on the one from Amazon is 22"... so maybe a little deeper/louder than stock, but not terribly loud.
D
Deleted member 80
Guest
The resonator helps with the helicopter drone when MDS is active. Plus, if you do much heavy towing you will quickly get tired of the noise IMHO.(says the grumpy old man)
hutchman
Mar 12, 2019
Yes it is, and I remember that one being a bit loud. I need to measure mine because I can't be certain on the length. I do think this one is louder however. But I do know they are 3.5" in/out. The muffler shop that installed the one I have now had to order one.
I'm going to the Tri Cities tomorrow to try and buy a new car, so maybe tomorrow evening I can get it measured.
Should be an interesting day!
hutchman
Mar 12, 2019
I traded, but don't have it yet. I'll start a new thread when it arrives!
KB RAM
Jun 3, 2019
San Diego
the maganflow website says they have a direct fit muffler coming out soon. I'm picking up my truck this weekend, I'll most likely buy a large magnaflow muffler and make it fit.
Randy M
Feb 19, 2019
Revisiting this thread it looks like Magnaflow has three different options. Since I have a PW I'm wondering if I get just the D-Fit muffler replacement and keep back half with the small muffler if that may be the way to go? Not really sure what the smaller muffler closer to the exit pipe is there for, and how it interacts with the main larger muffler further upstream.
https://www.magnaflow.com/collections/exhaust-system
