Add automatic wipers
Dinostop
Jun 1, 2021
I replaced the sensor behind my mirror with the sensor that also does automatic wipers, I added the 2 codes using alpha OBD. My wipers now do not work in intermittent mode and do not automatically turn on when raining. It is raining pretty good and I started my truck to test it. Any ideas?
2021 Ram 3500 Big Horn.
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
What is the part number of the sensor that was there before? What is the part number of the new sensor? Is there a “window” in the black frit pattern on the windshield for the sensor to see though? What are the two settings you changed with AlfaOBD? What faults are you getting in the BCM?
Dinostop
Jun 1, 2021
@Jimmy07
New sensor is 68298468AA
Don’t have the old sensor with me
Yes there is a “window” for it to see through
The fault is: u0321 lost connection with rain sensing module
Changes using alpha obd were
Veh config 2 rain sensor present
Custsetmenu 1 rain sensing wip
Jimmy07
Apr 5, 2020
That sensor is for humidity only (for the 1500 dual zone ATC). You need part number 68298334AA for rain sense.
Dinostop
Jun 1, 2021
@Jimmy07
I ordered the part number you noted and I do not get any trouble codes, but when I turn the wipers on they act as normal. Both of the OBD codes were added and I se the option in the radio. Any thoughts?
Jimmy07
Apr 5, 2020
What are the settings you changed?
Jimmy07
Apr 5, 2020
Is LIN & Misc: Humidity Rain Light Sensor Present set to yes also?
Jimmy07
Apr 5, 2020
With rain sensing wipers turned on in the radio settings, when you turn the switch in any of the intermittent modes, do the wipers behave more like a series of erratic “ghost” wipes than the normal wiper operation?
Try running the light rain sensor re-adaption. It is in the same list that car configuration change is in.
Dinostop
Jun 1, 2021
@Jimmy07
I have left the truck sit for 2 nights with moderate driving in between. I double checked all the options as previously noted. Yes they are irrational in timing when in intermittent modes. I get an error when running the re-adaption that says something about can’t run do to certain parameters.
Jimmy07
Apr 5, 2020
If it is constant erratic behavior, then there is probably either air pockets, or dust trapped between the windshield and adhesive membrane of the sensor.
Dinostop
Jun 1, 2021
I’ve ordered a new gel pack and will work on it when it comes in.
Dinostop
Jun 1, 2021
No one seems to had the gel packs. I removed the sensor and put it back on pressing firmly. I didn’t see any dust or anything in the way of the sensor. Still erratically turning wipers on and off.
blbrown
Feb 20, 2021
We're you able to get the rain sensor to work?
Dinostop
Jun 1, 2021
Unfortunately no I did not. The wipers are sporadic and the gel looks clean and bubble free. Not sure what I missed but I gave up until I can find someone that has been able to get it working.
blbrown
Feb 20, 2021
I'll probably purchase the one Jimmy07 recommended sometime after Christmas, I'll let you know how it goes
blbrown
Feb 20, 2021
I purchased the sensor you recommended here, haven't installed yet because I am concerned this might not also support the dual zone ATC which the existing module is for. Does 68298334AA support both functions?
Jimmy07
Apr 5, 2020
Yes. The one you originally have is only a humidity sensor for ATC. The new one is both rain and humidity sensor.
