- Joined
- Oct 5, 2021
2022 Ram 2500 Diesel
Anyone have issues with the new AF53034051AB? I installed the AB filter from Geno's garage and my regens have changed from 200 miles (14 miles commute with 15F cold starts) to 100-120 miles (50 miles commute with 45F cold starts) for 6 weeks, basically since i've installed the filter. I thought it was the cold weather cold starts causing issue and having been running checks with the CTS3 on all my sensors and injectors. I've been watching the dpf % on the CTS3 for 2 days now and thought the data was wrong since I was reading 50% soot levels with 0% on the truck screen. This morning CTS3 dpf % jumped from 56% start to 80% within 10 miles and the dpf truck screen went from 0 to 30%. Once I got to operating temps I noticed I was passive regening when I lugged the engine @ 75 miles ( egt2 +660 F) but it looked like it was a fine line of hitting the dpf filling on or off. It correlated with boost pressure +4 psig. I pulled off the highway and made a few stops on the way to work and the dpf % stop climbing. Let the truck idle for 30 mins at my work parking lot and the dpf % didn't change 1% during idle while it would climb 1% every 30 secs while in boost. Sent an email to Geno but might need to start testing a few filters. Going to take my short commute home with more city driving and stay out of boost to further test my hypothesis.
The CTS3 can show 99% with 0% on the dash because time is also a factor in there. When the CTS3 DPF % is time based you should see it increase 1% every ~14 minutes of runtime.
You cannot lug these engines, the programming won’t allow for it.
Your CTS readings sound like driving style, not air filter issues. The airflow at a few psi boost is minimal, if you want to test the air filter put a WOT load on it and see if you get an air filter change message.
Why did you idle for 30 minutes? That doesn’t help the DPF loading.
