Finally got under the truck to check the serial.. 2K-2699. Not sure if that’s bad, but I think it’s not definitely good since it doesn’t start with a 3.Did they fix the AISIN before you took delivery?
Wow. I am poking around in TechAuthority to work on the wiring needed for the dual fuel tanks, and happened to look up the TSB. I don't think I had carefully read this section before:Finally got under the truck to check the serial.. 2K-2699. Not sure if that’s bad, but I think it’s not definitely good since it doesn’t start with a 3.
Mine was built Dec 3rd. I am in the clear by the skin of my teeth. Phew.
Leveling System has arrived
This may be the part of the truck I am most excited for. An EQ Systems hydraulic auto leveling system, just like a class C or A might have. Basically, pull into camp (...or maybe a rest stop depending on the surface), dump the air bags, push a button and the truck levels itself out. No more rocking on the tires and suspension.
This is roughly the same kit that you'd get on a Dynamax Isata 5, with some slightly shorter front jacks as I need to fit them under a crew cab vs. behind a regular cab as Dynamax does. It's more than strong enough to lift the entire truck off the ground, even with the camper and a trailer hooked up.
I'm looking forward to getting started on that, but I have to finish a few other projects first. I hope to get the height sensors welded in for the front tomorrow, and my brake lines (yes brake lines) for the midship fuel tank should also arrive tomorrow. Still waiting on the last fuel lines to ship. I also need to get the air control system mounted, plumbed and wired. Then it'll be on to this new toy.
WELP
This is the result of taking two approximately 80" hard brake lines, shoving them into a box 75" long, and then shipping them to me, the customer.
Other than a few angle bends, all those big crazy straw bends are packing damage.
More setbacks for silly reasons..
