3.5" to 7" Cluster Upgrade
turbojay
Jan 1, 2021
Researching upgrading the gauge cluster in a 2020 2500 6.4 Tradesman with 3.5" cluster to the 7.0" cluster. If I buy a brand new OEM gauge cluster, would it be plug and play? It's unclear to me if the mileage/hours would need to be programmed on a brand new oem cluster or would be read from the BCM. Any info would be appreciated.
Jimmy07
Re-coding from an easy-chair
Apr 5, 2020
You can’t buy a brand new cluster from a parts supplier. You have to source one from a wrecked truck. It will be plug n play, but you’d have to get the mileage corrected. There are companies out there that can do it for you, or there’s AlfaOBD, but it is hit or miss on successfully changing the mileage and hours.
I figured the odo and hrs would be stored in the bcm at this point with the way they have everything integrated
Jimmy07
Apr 5, 2020
Mileage is stored in multiple locations, including 4 different spots in the PCM. One module is not capable of “pulling” the mileage from another module.
Jimmy07
Apr 5, 2020
Pretty pricey option but comes with them programing your new cluster to work with your truck...
Guage Upgrade
Yeah, infotainment is out of their minds, and prey on people that don’t know any better. You can find one at a junkyard yourself (that’s exactly where they get theirs from), and send it off to get corrected for a total of less than half that price.
turbojay
Jan 1, 2021
Jimmy07,
So your saying if I purchased a brand new OEM cluster I would still have to send it off to one of the programmers? Is there a recommended programmer for the Ram clusters? I noticed there are several advertising on ebay. Thanks for any info.
Jimmy07
Apr 5, 2020
I’m saying that you can’t buy a brand new cluster...at all. If you go to a mopar parts supply site, and put it in your cart and pay for it, the order will be canceled a few days later. They can’t sell a new cluster directly to you.
You need to find one from a wreck, and either use AlfaOBD to correct the mileage and hours (hit or miss on whether it works), or send it to somewhere like infotainment to correct the mileage and hours.
Glad i saw this before trying to order one
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
I knew better, but it was the easiest path to success, for me.
Matts2500
Nov 10, 2022
I have a 2022 2500 Tradesman with 6.4. I want to start look for the better cluster. Mine just has a pretty basic cluster. Anyone know what the correct part number is for the upgraded cluster? I’m not paying Infotainment’s ridiculous prices.
Sam 15
Aug 9, 2022
Palm Desert
I bought my upgraded instrument cluster for my 2014 6.4 form this guy. Looks like he has a few listed. You send him the milage on your cluster and he will program it into the one you are buying. Make sure you check which one for gas or diesel. mine was plug and play...easy peesy.
kristof
Aug 27, 2020
So what is the process of upgrading the cluster on 2020 Ram 2500? Do I just find one and it should be plug and play? Then just change the mileage? Or I should look for specific part number? I know it have to be gas version
Musclelogic
Dec 6, 2023
In my research so far, 19-22 will interchange, 23-24 are different since the 23+ trucks got the true 5th gen steering wheel and lefthand buttons.
Yes, you'll have to program miles and hours via AlfaOBD.
kristof
Aug 27, 2020
I upgraded the cluster and I have couple of questions. First the mileage. My truck have over 88K miles on it. New cluster came with over 5K miles on it. When I correct it in alfaobd it went up to little bit over 55K and not 88K.
Second question the fuel range it shows as 1999 miles which is impossible . Should I wait little bit more before I try again? Only drove about 15 miles after the upgrade
Jimmy07
Apr 5, 2020
You need to enter your mileage in alfaobd to the km equivalent, then tweek it from there. What it sounds like you’re saying sounds backwards- ie, if your current mileage is 55,000 miles, then you’ll enter ~88,500.
The dte range will go down to normal after a bit of driving.
kristof
Aug 27, 2020
Okay will do that. Also how come the cluster won't read the mileage from computer?
kristof
Aug 27, 2020
Mileage range start dropping. But my fuel gage keep showing full tank. I assume it's because the range is still over 800 miles? There is no floater inside the tank?
