But don't let it idle too long!I as well used EGT1 temp for monitoring turbo temps. I use about 450F as a temp to get down to (if needed) before I shut it down - what temp are you targeting before shutoff?
lol, you know it - it only takes a min or maybe too after towing heavy to come down - unloaded driving doesn't need any cooldownBut don't let it idle too long!
You can, its just expensive on the 22s along with the other risks that come with it based on where you live. Either way as others have stated this tends to get overthought a lot.At the risk of getting raked over the coals... I wish I could DELE..!
I come by my mind ****ing honestly...the internet...I don’t watch anything. I get in start it up and drive. Too many people are mind ****ing the issue.
I don’t have a set number, but 450° is probably good.
I also watch ECT as it stays high for longer thanks to the EGR cooler.
Welp, made it 173 miles and 5 hours run time to next regen. This thing makes no sense, sits on 0 for a week, then jumps to 15% full, then goes to 45% full within a couple days, then goes into regen. Unfortunately it starts to regen on my way to work in the morning, so I have to shut it down during the cycle.
Our situations sound very much the same. I would agree with the fact that when I'm towing it doesn't hardly ever regen. I am just curious if I am going to start throwing codes because I have to drive the damn thing to work...?Yeah, I have noticed my truck going into regen mode more as of late. No idea on mileage between regens but id say it has done 2 regens on one tank of fuel, I can tell is in regen based on how it sounds at idle. Depending on my drive time it can take 2-3 drive cycles to complete a regen. I have not towed anything since roughly October, couple of road trips unloaded but the majority of my driving has been 20 minute trips to work twice a week. I am a firm believer if you tow with these trucks you will have minimal issues, they need to be worked. I was able to get our trailer out yesterday and towed it 4 hours yesterday. I will monitor the DPF screen and see how it does now. Last summer when I was towing nearly every weekend my DPF gauge pretty much stayed on 0.
I have 18K on mine. Have tried Hot Shot Everyday Treatment too. Next tank not going to put anything in it.How many miles? Glad I haven't experienced that, yet... Mine never smells bad, just smells like melting rubber. I added some HSS extreme to the tank the other day and it did a regen much quicker than normal, see how that goes?
Crazy! A 10 mile regen is far more to worry about than my 130 mile regen. Why is the Cummins having these issues all of a sudden? I was under the impression that they had the most dialed up DPF situation of the big 3.
Your 130 mile regen could be normal. I have been commuting in my truck the last two weeks just to watch it. I completed an active, 24 hour, regen 7 hours ago. My PID %age has slowly been creeping up (73%), faster than when I don't commute regularly by far, and my DEF gauge is at 30%. I don't have any stop and go on my commute, but some of my errands have had a little. The highest I have seen EGT3 is 700°, and not for long. Very little time above 600°, which means almost no passive regen in the last 7 hours. It all seems normal, and I am sure if I did this for another 3-4 hours I would go into regen long before the 24 hour mark. I'll likely get some good passive regen prior to that thou.
While I am already over the 130 mile mark there could be slightly more soot accumulation in your driving route/style than mine, and that could trip it in that many hours.
I do think Ram has the most dialed in Emissions setup, but that can't compensate for driving conditions.
That's why I'd be interested in experimenting with a tank of it or even just running it down to a 1/4 tank and filling it up to a half. Worst case go top it off with with some normal #2 if it's unhappy about it and call that experiment failed lol. I've noticed this new SO doesn't care for the standard 40 cetane truckstop fuel much over past engines and just seems "happier" if it's either boosted up or I'm filling up with the 48 Cetane TXLED stuff.I’m not sure I would run diesel with a Cetane if 70+ in these trucks, they are not programmed for that much.
I haven’t had it happen on my 6.7’s, but my 05 5.9 did not like even a 4 point Cetane boost on stock tuning. It would knock like a bad wrist pin at low loads until I got a new tank of fuel. Only did that twice
The 6.7’s seem ok with a 4 point boost in cold weather, but I won’t go more than that.. it’s just not in the programming profile to work with that little ignition delay.
Im new to the diesel world, what is "regen"?Is this expected? Seems excessive to me... HWY and towing is much better however.
