I get you, just not much different I can do, aside from less idle time...
Keeping idle time to a minimum will help substantially. Idle only serves to add soot that has to be burned out, often times creating face plugging of the DOC / DPF. Extended idle time plus a considerable amount of low-load or no-load is a fast combination for increased regeneration and potentially the need for a stationary desoot. (I wish we had the ability to trigger these ourselves, without the need for a scan tool)
You may also find that using an additive (either or routinely or every so often) may help your situation. Prior to this 22 truck, I was not much of a believer in additives. I operated on the “it’s engineered for straight diesel” principle. I had a short period where I felt my own truck was also regenerating more frequently. I very quickly found out my dealer had given me the incorrect engine air filter, so that got addressed pretty quickly. But I still noticed what I thought to be a faster than expected accumulation of soot in the DPF. On a whim, I decided to try the hotshots extreme and the hotshots edt. Extreme is a one time dose every 6k miles and the edt is used in every fill up. I do truly believe these two made an improvement in the way my engine and emissions system functions. After I started the treatment regiment, I noticed my truck does not build soot as quickly, and it would seem regeneration cycles are more effective (both passive and active) I’m not saying it’s the solution to every problem but I do believe it enhanced the situation rather than detracting from it.
There are so many variables to consider with these trucks. Drive cycles, operating environment, the driver itself, the fuel you use, the engine oil you use, how often do you idle?, how often you tow or work the truck, and the list goes on.
Ultimately the easiest thing to do is establish a baseline and see how things go over a period of time. Like I said before, these systems self diagnose and monitor parameters. If there’s a problem brewing, you’re likely to find out via an MIL. In the meantime, some basics like reducing idle time (Cummins Inc. says keep idle time to 15-16% of total engine hours or lower), putting the truck under load intermittently, etc will all help to reduce how much you need to regen.
