Add me to the list. 2022 Ram 3500 Limited Longhorn with Aisin and 4.1 gears.
Transmission failed on 7/31 while towing with 4161 miles on odometer. Overshot an entrance backed up 10’ and when it went back into drive no bueno.
Ram had the truck for a month to replace the K1 clutch assembly. Got it back, drove terrible, as if it was slipping gears every time it shifted from 2-3, 3-4, and under higher load. They said it should “learn” and smooth out. 1.5 weeks later I had a chance to get it back in. They test drove it and other trucks for a day, couldn’t identify an issue, pulled the transmission and said it failed, and needed to be replaced.
I’ve now been waiting on a new transmission since second week of September.
Ram care will not reimburse payments until truck is completed. They will not reimburse for two trailer moves. They cannot find the original transmission, and cannot seem to find a process to order a new one. At my wits end with these guys.
That’s an incredibly long time to be waiting for a transmission. What is the dealer saying?
I can add your truck, just need the following information:
1. Date you ordered the truck (if applicable)
2. Date of manufacture (See sticker on driver door for "date of manufacture (Build date))
3. Date you purchased the truck
4. Mileage on odometer at the time of failure
5. Serial Number of failed transmission (see blue stamped metal tag on side of the transmission. It will be something like "2H-2345"
6. Serial Number of replacement transmission (if applicable)
7. Were you towing at the time of failure?
8. Did 1st through 4th gear work?
9. Did reverse work?
10. What date did the transmission fail?
11. When was the truck returned to you after repair?
12. Did your dealer replace the transmission with a new unit or was the failed transmission repaired with parts?
13 Was / Is the truck currently identified under Customer Satisfaction Notification 71A?
If the truck experienced multiple failure dates, please provide dates for failures and repairs.
