May as well add ours to the list.
May as well add ours to the list. 2022 transmission failed while towing 1654 miles
Will do. Can you get me the following information for the spreadsheet:
1. Date you ordered them truck (if applicable)
2. Date of manufacture (See sticker on driver door for "date of manufacture (Build date))
3. Date you purchased the truck
4. Mileage on odometer at the time of failure
5. Serial Number of failed transmission (see blue stamped metal tag on side of the transmission. It will be something like "2H-2345"
6. Serial Number of replacement transmission (if applicable)
7. Were you towing at the time of failure?
8. Did 1st through 4th gear work?
9. Did reverse work?
10. What date did the transmission fail?
11. When was the truck returned to you after repair?
12. Did your dealer replace the transmission with a new unit or was the failed transmission repaired with parts?
13. Was / Is the truck currently identified under Customer Satisfaction Notification 71A?
