It currently at a dealer in Gander NL, Canada. Ramcare gave them the green light to diagnose and repair/replace the transmission. Still waiting on word from the dealer on ETA and getting my truck back to me.
What do you need for info?
Ok that’s good. At least they can get it diagnosed.
I’m going to get you on the spreadsheet.
Here’s the list of info I take from every truck represented on the list. Please do your best to provide as much of it as you can right now. Your trucks date of manufacture is an important one.
1. Date you ordered the truck (if applicable)
2. Date of manufacture (See sticker on driver door for "date of manufacture (Build date))
3. Date you purchased the truck
4. Mileage on odometer at the time of failure
5. Serial Number of failed transmission (see blue stamped metal tag on side of the transmission. It will be something like "2H-2345"
6. Serial Number of replacement transmission (if applicable)
7. Were you towing at the time of failure?
8. Did 1st through 4th gear work?
9. Did reverse work?
10. What date did the transmission fail?
11. When was the truck returned to you after repair?
12. Did your dealer replace the transmission with a new unit or was the failed transmission repaired with parts?
Obviously some of this is irrelevant right now as your truck isn’t repaired. When you get it back, we can update the data then. Whatever you can provide for now is good enough to get you started on the spreadsheet.
