Darkone
Does that mean that tradesman with the power wagon package has a different axle too? I can’t see ram doing that honestly.
I didn't know this... so my gears do exist. I've been looking for 22 PW gearsThe axles are different. The PW uses the prev-gen axle, while the other 2500s use the newer version.
Dual tank setup? Share share!!!I installed 5:13s in my 2020 PW in May of 2020 only difference was the rear pinion bearings and front pinion seal. Have 21k miles on gears with no issues. I installed the gears before I shipped truck in to AEV.
View attachment 45411View attachment 45412
Wow that is super cool thanks for sharing! How much capacity is the rear tank?I bought the Titan Diesel spare tire tank and a 2016 1500 bed side with filler tube. Had a great body shop guy add the factory second gas door in the bed.
I purchased weld on 3/8 hose barb fittings and added them to the factory PW filler tube for the transfer pump. I had to add a one way value to the vent tube to keep the check engine light off. Install was very easy. Built a 3/8 plate skid plate with 1/4" hold downs.
For safety and mainly liability reasons Titan will only sell for Diesel trucks. Due to the fact the FMSCA and Federal DOT outlawed Gas tanks behind the rear axle after 2006. So I do not recommend this install. But it works. View attachment 45413View attachment 45414View attachment 45415
I’ve been wanting to re-gear my 2019 since I upgraded to 37’s. Can I ask where you found this 5.13 set and what you did to address the different pinion bearings and seal?I installed 5:13s in my 2020 PW in May of 2020 only difference was the rear pinion bearings and front pinion seal. Have 21k miles on gears with no issues. I installed the gears before I shipped truck in to AEV.
