2019+ Power Wagon gear availability
Rockcrawlindude
a rock crawlin’ dude
Jan 1, 2021
Georgia USA
I had a bit of a drive on the way home today so I decided to call Yukon and speak with tech-support. FYI I ended up being transferred to Randy’s and I spoke with Gus.
Gus knew exactly what I was talking about when i asked about the differences in the 2019 + trucks from the 2014+ trucks
I will try to explain what he said to the best that my very very poor short term memory would allow me to remember from the time we spoke to the time I could make this post.
2019+ power wagons use the old front end stuff
Non PW 2500s use the same front ring and pinion set but new style bearings.
All 2019+ trucks have a new 32 spline rear end it’s slightly different
TLDR: yes they’re different. But, Both power wagon and 2500 trucks have factory gear sets available so you can regear to 3.73, 4.10 or 4.44 at this moment. No aftermarket options are available until fourth quarter. (Currently in development)
Personally, I’m hopeful for Yukon 4.30s
redgoat00
Oct 10, 2022
I bought the Titan Diesel spare tire tank and a 2016 1500 bed side with filler tube. Had a great body shop guy add the factory second gas door in the bed.
I purchased weld on 3/8 hose barb fittings and added them to the factory PW filler tube for the transfer pump. I had to add a one way value to the vent tube to keep the check engine light off. Install was very easy. Built a 3/8 plate skid plate with 1/4" hold downs.
For safety and mainly liability reasons Titan will only sell for Diesel trucks. Due to the fact the FMSCA and Federal DOT outlawed Gas tanks behind the rear axle after 2006. So I do not recommend this install. But it works. Screenshot_20221010-221258.pngScreenshot_20221010-221117.pngPXL_20201113_181622173.jpg
jetrinka
Jun 11, 2021
For safety and mainly liability reasons Titan will only sell for Diesel trucks. Due to the fact the FMSCA and Federal DOT outlawed Gas tanks behind the rear axle after 2006. So I do not recommend this install. But it works. View attachment 45413View attachment 45414View attachment 45415
Wow that is super cool thanks for sharing! How much capacity is the rear tank?
@JC
Jan 22, 2020
Looks cool, but the last thing I'd want to do is add any weight behind the rear axle on my PowerWagon.
redgoat00
Oct 10, 2022
Adds 30 gallons of gas. Yeah, the wagon scales out at 11,650 split 40/60 front to rear heading out W/ 62 gal fuel, 30 gal water in the side tanks, a grip load of tools and all supplies to last a week plus.
Kelsoff
Apr 14, 2023
I installed 5:13s in my 2020 PW in May of 2020 only difference was the rear pinion bearings and front pinion seal. Have 21k miles on gears with no issues. I installed the gears before I shipped truck in to AEV.
View attachment 45411View attachment 45412
I’ve been wanting to re-gear my 2019 since I upgraded to 37’s. Can I ask where you found this 5.13 set and what you did to address the different pinion bearings and seal?
