2019-2022 Dually largest oversized tire on stock wheels/truck?
Synolimit
Oct 18, 2023
No spacers, but running 2020 ford inners (17x6.5") which have a slightly higher offset. +6mm additional offset (IIRC). Same bolt pattern/hub bore. Going to replace the night edition rims with some aftermarket 6.5" wide rims eventually.
Surprised you did that. If the oem is 6” outer and the fords inner is 6.5”, this would give your rear tires different ride heights. Probably too small to tell but I wouldn’t have chosen that.
Synolimit
Oct 18, 2023
If anyone was curious, my OEM tires did pretty good. 59,000 miles on my 2022. If I lived in Texas or something I could maybe go longer but I will replace this fall. From looking at the pics here between the 255/80/17 and the 255/85/17, I think the 80 wins unless you’re lifted.
As for a spacer, a good lug nut only needs its stud width to grab and hold. If ours are 1/2” wide studs, half inch of grab should be fine. Stock looks like it grabs over 1” with some protruding out the lug. 1/4” or a 1/2” spacer should be fine but I wouldnt go 1/2” unless it’s hubcentric. You should be ok with 1/8-1/4” spacers that are not hubcentric. Just air up when towing.
MikeXM
Nov 30, 2019
I know this is old but my 3.73 is 34,070lbs towing. What would mine drop to with either the 255/80 or the 255/85?
"equivalent" drive ratio would be 3.59 (-4.1%) and 3.48 (-7.2%) respectively compared to OEM tire size. That is the drive ratio to drive the exact same distance with the different tire sizes.
It's an approximative ratio and is not considering all the physics involved. For example, the larger tires are also heavier so a bit more force is loss to make them spin.
CFE
Jan 3, 2022
Hello,
First time poster, been a lurker for a few months. After reading this post I bit the bullet and put on the Mickey Thompson Baja Boss AT 255/85/R17's on my 22 limited long bed. Stock suspension and no spacers in the rear. Looks are great except where the shop damaged all 6 wheels with the tire machine and will be replacing all 6 wheels. The tires are not touching (about 1/4" between the sidewall lugs) but I have the 1/2 spacer and will be installing tomorrow to give the rear duals more space in-between the side walls.
Thinking about finally biting the bullet on the Baja Boss AT in 255/85/17- just curious how you're still liking the Baja Boss ATs and how they're holding up?
CFE
Jan 3, 2022
and I settled for the Falken Wildpeaks A/T3Ws. I wanted the H/T versions but my tire shop said their vendor was all out of the H/Ts. I'll finally be able to junk the Nexens this weekend with ~33k miles.
G Mcpherson
Dec 20, 2020
Yacolt, Wa
I just recently installed a set of the Falken Wildpeaks. Good so far. I also have them on my Wife's SUV.
  • Like
Reactions: CFE
BigDually19
Jan 20, 2024
After reading this thread, I went with 255/80-R17 Nitto Recon Grapplers on my 2022 3500 DRW. I’m satisfied with the gap between the rear tires without a load (this is at 65 PSI). When I get my RV hooked up, I’ll let y’all know if there are any issues.
Hey i was just checking if you had towed with the new tires yet? And how the clearance was between the duals with a load on? Thanks
Aug 20, 2023
Good info and pics. This is helpful to many, thank you.
You ever get a chance to measure how much thread engagement those flanged nuts have with your spacers? Im trying to decide on 1/4, 1/2, or a 1" with some trimming.
Ugh. Too many choices
Mr Safety, reporting for duty!
RAM_GA
Dec 3, 2023
did you have any issues towing? How heavy is your 5th wheel?
