19 Current Gear Display
John Jensen
Feb 11, 2020
Easy peasy with Alfa
AlfaOBD:
Car configuration Change:
ECUConfig 4:
Actual Gear for Display - Yes
Vehicle:
Then go to EVIC
Select settings
Select Gear Display - Yes
Enve46
Jul 20, 2021
So AlphaOBD isn't compatible with Apple, which I joined that cult in 2017. That is a bummer
elephantrider
Hydraulic Lifter Crew
Sep 3, 2019
any android device will work. get a cheap 8 or 10 inch droid tablet.
phatboy64
Sep 20, 2022
I looked through JSCAN and didn't see where to set the gear indicator to display all the time. What module/steps do in need to use/do?
CdnHO
Nov 17, 2020
Ontario
Search for "Actual Gear for Display" and make it active. Once you have done that go into the radio menu and turn it on.
