sony224422
Will these not work with the 2025-26 trucks? I’m guessing it’s not fitment but because you can’t tell the computer you put a bigger tank on?
That is a good question I have been hoping someone would discuss. I have a 2025 myself. I am guessing we could physically mount the tank in place of the stock unit. I would also guess the fuel gauge would be off a bit, but would work. The distance to empty likely won’t be remotely close if that matters. I don’t have a clue what it would do to figuring the fuel mileage.Will these not work with the 2025-26 trucks? I’m guessing it’s not fitment but because you can’t tell the computer you put a bigger tank on?
I am hoping someone tries one to see what happens.I don’t want to be the first.
Update: Received the tank last week. I’ll fix it in the next weeks, along with other planned works. I’ll post the outcomes once completed.Firstly, thanks to the active support and momentum generated via this post, which eventually kept us engaged, and, helped triggering and driving the project to see the light.
Glad to share that last week I placed the order of the newly released larger Tank, after waiting on the list for more than a year.
I pass my many thanks to the customer-centric support exhibited by Teri, which streamlined the process from resolving couple of technical queries all the way to the order finalization, with extending my appreciation to the other behind-the-scene members.
Now, am awaiting the receipt of the tank and installation, following the long lead production and shipping prior activities.
Let’s hope for the best to all.
For the CTD trucks, supposedly the currently available Titan/S&B extended tanks for the 20XX-2024 models will not fit 2025-2026 because the 2025+ has a different size/location for the DEF tank. Perhaps this is due to the new transmission, new location for the t-case, etc.Will these not work with the 2025-26 trucks? I’m guessing it’s not fitment but because you can’t tell the computer you put a bigger tank on?
have you been able to get it installed yet? if so what year do you have?This is the sticker showing the Tank’s Part number, noting that I placed the order directly with the Sales (via “Teri”) for being on the preorder waitlist for more than a year, with thanks to the TF Team for their great customer attention and prompt support.
After installing, I’ll see how it’ll go with the fuel gauge reading and share the updates.
As a relevant note, currently I have a locally fabricated in-bed tank of about 120 liters capacity, with an external pump (used by old Mercedes) that is directly connected with the main tank’s steel feeding pipe. It’s inside the canopy with an in cabin reading gauge. The system worked well for couple of years but I do need to rely on a bigger main tank, while having lesser use of that aux. tank.
My PW is 2022. Not yet installed, but it’s on the plan within the next couple of months as part of other upgrade works. I’ll keep the forum posted upon completion.have you been able to get it installed yet? if so what year do you have?
This to update that the installation is in progress and soon I’ll try the new tank.My PW is 2022. Not yet installed, but it’s on the plan within the next couple of months as part of other upgrade works. I’ll keep the forum posted upon completion.
@FichtelUS,@Ahmed392 how was the install? Any issues you came across? Or as straight forward as it looks?
Thanks for the Info. Appreciate it!@FichtelUS,
According to the workshop’s feedback, nothing tricky and the work went relatively smooth as instructed in the enclosed manual. During the process, I was informed that the technician requested taking some time to read the manual and be more familiarized with the installation and steps to be followed. Once oriented, the installation continued with no issues. All parts for the new tank were professionally included by the supplier. Truly, well done and well packaged.
Progress note: Am still using the fist full tank and for the first time the truck crossed 650 km, with remaining estimated range of about 100 km (1/4 tank remains). Yet, this is conditional to the gauge’s calibration which is still ongoing.
I’ll post my collective feedback after consuming the second tank.
