TransferFlow Replacement Tank for Hemi
Will these not work with the 2025-26 trucks? I’m guessing it’s not fitment but because you can’t tell the computer you put a bigger tank on?
That is a good question I have been hoping someone would discuss. I have a 2025 myself. I am guessing we could physically mount the tank in place of the stock unit. I would also guess the fuel gauge would be off a bit, but would work. The distance to empty likely won’t be remotely close if that matters. I don’t have a clue what it would do to figuring the fuel mileage.
I am hoping someone tries one to see what happens.I don’t want to be the first.
They
2019/2020 truck owners are in the same boat...
They won't say why it won't work.
I would think with Alfa seemingly closer, you’d be able to change the tank size as it looks like it’s a hex code change. I will admit, while I’m decent with programming, I am not sure if it would require it to be an option or if you can manually tell it there’s 46 gallons and to do the calculations off that.
I’d be willing to bet it will physically fit just fine.
As for the 19-20, I wonder if something is slightly different?
Firstly, thanks to the active support and momentum generated via this post, which eventually kept us engaged, and, helped triggering and driving the project to see the light.
Glad to share that last week I placed the order of the newly released larger Tank, after waiting on the list for more than a year.
I pass my many thanks to the customer-centric support exhibited by Teri, which streamlined the process from resolving couple of technical queries all the way to the order finalization, with extending my appreciation to the other behind-the-scene members.
Now, am awaiting the receipt of the tank and installation, following the long lead production and shipping prior activities.
Let’s hope for the best to all.
Update: Received the tank last week. I’ll fix it in the next weeks, along with other planned works. I’ll post the outcomes once completed.
If you install the new TF tank, will the gas gage be accurate?
This is the sticker showing the Tank’s Part number, noting that I placed the order directly with the Sales (via “Teri”) for being on the preorder waitlist for more than a year, with thanks to the TF Team for their great customer attention and prompt support.
After installing, I’ll see how it’ll go with the fuel gauge reading and share the updates.
As a relevant note, currently I have a locally fabricated in-bed tank of about 120 liters capacity, with an external pump (used by old Mercedes) that is directly connected with the main tank’s steel feeding pipe. It’s inside the canopy with an in cabin reading gauge. The system worked well for couple of years but I do need to rely on a bigger main tank, while having lesser use of that aux. tank.
For the CTD trucks, supposedly the currently available Titan/S&B extended tanks for the 20XX-2024 models will not fit 2025-2026 because the 2025+ has a different size/location for the DEF tank. Perhaps this is due to the new transmission, new location for the t-case, etc.
I know this has nothing to do with the 6.4 trucks, but if true, it indicates that some things might have moved around under the truck for the 2025+ model facelift.
have you been able to get it installed yet? if so what year do you have?
My PW is 2022. Not yet installed, but it’s on the plan within the next couple of months as part of other upgrade works. I’ll keep the forum posted upon completion.
This to update that the installation is in progress and soon I’ll try the new tank.
From the moment you unpack the tank, you’ll realize that you made the right choice and took the best-fit decision to buy the bigger tank from Transfer Flow. Thanks to the teams working behind the make of such a great tank.
It truly looks superior in quality of material and welding, including packing. The tank was pre-fitted with all necessary hoses and all you need is just to reuse the fuel pump with installing the bracket.
I’ll keep posting on the progress.
ebd24230-0fdc-40c7-a3d0-1d421922bdcd.jpeg42a9bc4c-56cb-4d69-9cf7-1ea6d922c043.jpegd8e3d923-de8f-4c6f-b8ac-28a431c66dcf.jpega90b5f30-0d37-41b0-94ae-6cedfd5ff3a3.jpegb3649bb0-18ca-4c15-8f36-e10ca56ea6ea.jpeg22ba3386-7d79-423e-ac12-ea1d99ee3731.jpeg76544d3b-5ec6-4357-b1a6-2fb1ebccec4e.jpeg
So I was referred to the previous thread (50gal tank) by someone on Ram Forum, then followed the link to the "harass Transfer Flow into making the tank we want" thread. (Well done, gentleman) And here it is. A tank I've been looking for 3 months. (including my certified Ram dealership ordering a 50gal tank, and them not knowing what to do with it)
Now I have just one question that no one has raised yet....... Is this going to void my 7 year/100 mile PT warranty?.... (I bought a 2022 certified pre-owned, which on a gas burner, extends the 5yr/65k PT warranty to 7yr/100k)
I mean, I love 5th gen Rams. (I'm on my 3rd one) ...but it's a Ram. I absolutely do not want to void my warranty.
Has anyone considered or checked on that?...
Any feedback would be appreciated. Thank you.
Nice. How does the gauge work/reflect the additional capacity?
@Ahmed392 how was the install? Any issues you came across? Or as straight forward as it looks?
@FichtelUS,
According to the workshop’s feedback, nothing tricky and the work went relatively smooth as instructed in the enclosed manual. During the process, I was informed that the technician requested taking some time to read the manual and be more familiarized with the installation and steps to be followed. Once oriented, the installation continued with no issues. All parts for the new tank were professionally included by the supplier. Truly, well done and well packaged.
Progress note: Am still using the fist full tank and for the first time the truck crossed 650 km, with remaining estimated range of about 100 km (1/4 tank remains). Yet, this is conditional to the gauge’s calibration which is still ongoing.
I’ll post my collective feedback after consuming the second tank.
@FichtelUS,
Thanks for the Info. Appreciate it!
