Just wanted to share an update on my frequent regens issue. My truck had been running a regen every 150 miles and 3-4 hours, and has been doing this since a dealer in VA flashed the ECU when I was in for a going into limp mode message. The last few days I have been pulling my 15k# 5th wheel so I am running pretty heavy. 2 days ago, the truck had done a regen prior to leaving on our trip, ran about 300 miles the DPF gauge starting out around 15%-20% and within 100 miles was reading zero. Stopped for the night a couple of miles off the freeway, today when I started the truck, DPF gauge read zero, within 1 mile it was doing a regen. Ran another 200+ miles today and at the 80 mark the DPF gauge started climbing and ended up a little over 25% when I got to my destination today. I bought a scan tool and have Jscan (still demo mode) and I have the following codes, P2509, P026B and surprise P2459. While
While driving the last 2 days EGT is right around 655.
Why are some codes marked as active and some as permanent?
I am still convinced that the dealer that flashed the ECU last fall screwed something up, but can’t prove it. What else do I need to check?
Should I buy Jscan or is alphaOBD a better product?
Thanks
