I had to delay the drop-off of my truck until the other day but I just picked my truck up this morning and although I asked them about inspecting the whole intake, exhaust, and fuel system for leaks, it sounds like all they did was inspect the DEF system and air filter. The truck wasn't in auto regen when I picked it up (the gauge read about 35%) but I jumped right on the freeway at 85 when I picked it up and it was in auto regen within 3 miles. I called Ramcares and they told me to take the truck back to the dealer and that they would work with the dealer on fixing the issue. The prinotut I got from the dealer when I picked it up reads...
"I check and found dtc P0421-00-CATALYST 1 EFFECIENCY BELOW THRESHOLD BANK 1. I checked and found the there is a PCM sofware update available this update will be performed on line C with the recall (Y43). I checked and printed out the vehicle duty cycle report and found that the vehicle is still being operated in light load conditions this is not allowing the after-treatment system to complete the regenerations cycles and can cause damage over time. I left a printout of the duty cycle report in the vehicle. the customer needs to be made aware that if they continue to operate the vehicle in this manner after-treatment damage may occur. I removed and inspected the engine aitr filter and found that the air filter is the updated style without the glue strips. the air filter is slightly dirty but is not restricted at this time. I inspected the def system and found no leaks or damage at this time. the def system is full and no other dtc's are reported at this time."
This is frustrating, they talk about light load conditions but in the roughly 1,500 miles since I last had it in the dealer for this I've driven almost exclusively on the freeway usually around 85 MPH and had roughly 300 miles on the freeway with an aprox. 9,000 lb trailer behind it. I can't get a straight answer out of them as to how long I should have to drive at highway speeds with or without a trailer to come out of auto regen.
Below is a breakdown of the miles and driving since the dealer last saw it of when the truck was in and out of auto regen, the most miles out of auto regen were 31. Every time it WAS NOT in auto regen was in a situation where I turned the truck on and the DPF filter happened to be at zero, there was never a time while driving that the auto regen screen just went back to the filter gauge instead of the regen message.
EDIT: I realize that this chart below is misleading a bit, the "Since Last regen" column needs to change... the only time the truck with NOT in regen are 22, 31, and 18. the other miles are all regen time between the lower numbers.
| Auto Regen | Miles | Since Last regen |
| On | 9526 | NA |
| Off | 9889 | 363 |
| On | 9911 | 22 |
| Off | 10353 | 442 |
| On | 10384 | 31 |
| Off | 10660 | 276 |
| On | 10678 | 18 |
You can see below what it looks like when I'm driving highway speeds watching the gauge climb, it goes from roughly 35% at 10,375 miles to ~45% at 10,381, back into regen at 10,384.
View attachment 62321View attachment 62322View attachment 62323
I don't know that I'm necessarily looking for anything here as I already have some great info from this community and now have a ticket in with Ramcares but any feedback is welcome. As of now this is almost just another place for me to document what is going on.
