gprguy
Weather's about to change here and go from nice to fall starting tomorrow, so we did some leak testing on the cabinet. Only a few small leaks, some of which I've already fixed, one or two that need further investigation, and some others that I kind of expected. I need to build some baffles for the front vents, if water sheets down there it tends to get a little inside since the louvers don't overlap. Also the DEF hoses need some sealant added to the grommets. After that, gave the truck a wash for the first time in close to a year.
The amount of filth that came off the truck was impressive. After that it was back to working on the bed - I finished up hopefully the last of the welding on the underside of the steel frame, other than some brackets I need to add for the future storage boxes. I've also started attaching the aluminum top to the steel bottom using these brackets I picked up.
There will be additional, stronger things holding the deck down as well - but these will help locate it and keep it snug when there isn't a load on it.
I've also started reworking the front fuel filler - I decided that if I made the front one more rectangular instead of an angle down to the deck I'd have room to hide both the 7 way and the Lance 6 pin connectors on the backside. Something like this, but of course spaced a bit better.
On the front side I'll leave the angled bit for triangulation, and just square it off above.
Once I have the filler at least tacked together it'll be back on those little brackets, and then more on the aluminum deck.
