Tl;dr - If you live in or around the Atlanta area with a fifth gen rattle, go see Ram Diesel Specialist and have them install the Hamilton Flat Tappet conversion kit. You won't regret it.
I wanted to take a moment to document my story, which like many others, began with a slight tick. I've linked a few videos at the end of the post that show the symptom pre-fix and a tribute video for the fix being installed. A little context that should answer most of the initial questions:
- 2023 RAM 2500 SO 6.7 ISB
- Climate/Locale: Southeast US (Atlanta)
- Current Mileage/Hours/Idle %: 38,500/950/16%
- Oil Used/OCI: Valv PB 5w40, Shell T6 10w30/Every 7500 miles
- All powertrain/emissions equipment are factory and still under full warranty
I originally noticed the faint tick around 24,000 miles at high idle when at operating temperature. Over time, this faint tick became a loud rattle and very pronounced in tow-haul mode (undoubtedly from higher operating characteristics). I began searching here and over at CumminsForum to see if others were experiencing the same issue, as well as to informally confirm my suspicion that it was likely valve train noise from the HLAs. NOTE: I'm not going to rehash the fifth gen HLA failure modes here. This is well documented on this forum and over at cumminsforum.com
Here's a
warm idle video, a
high idle video, and a loaded
power brake video all documenting the rattle symptom. This is what I was working with...
NOTE: I'm intentionally leaving out dealer names here, but if you love in or around the Atlanta area, I'd be happy to share specifics in a PM.
Enter diagnosis attempt #1: I called around to see how many diesel techs each dealer had, and if they had encountered the valve train failure common to these fifth gens. Unsurprisingly, many (if not all) of the dealers inside the perimeter had one diesel tech or none at all, and no dealer in Atlanta claimed to have any experience with valve train failure. I ended up taking it to a reputable dealer in Gwinnett county who claimed that "all of their techs were diesel certified", but most importantly, they had appointment availability inside of a week. What a miserable bunch of humans... My truck sat at their shop for almost 3 weeks with a tech who only wanted to treat me like an idiot (as if I've never owned a diesel engine) and who insisted that the noise was a "loose heat shield". He also berated me for "using the wrong oil" in the truck (I was using Valv PB 5w40 at the time) and that it was somehow related. After 3 weeks of no progress, I demanded to get the truck back with writing which stated they confirmed there was a mechanical issue, but were unable to diagnose it.
Enter diagnosis attempt #2: Back on the phone - I found a few dealers in North Atlanta that had diesel techs, but were booked out for weeks. It's important to note here that none of the dealers I ever worked with were willing to provide a loaner, nor was RamCares willing to reimburse a rental. I finally found a "truck center" which seemed knowledgeable on the RAM HD platform, but also claimed they had never encountered valve train failure on a fifth gen because "the Cummins is too good for that". What a moron that guy ended up being. The truck was in their shop for 72 days. 14 days to finally diagnose the issue as "scissor gear failure" (go figure), but would require cam, lifter and rocker replacement. I chose at the time to not argue about the scissor gear diagnosis because it landed the repair I was seeking. They sent several pictures of the cam which definitely had strike damage from what I thought would be collapsed lifters. Turns out, after finally getting the truck back, the tech agreed. His notes indicated that he found several collapsed lifters, cam damage and a few other minor things that appeared unrelated, but no mention of the scissor gear. What I didn't know was things were about to get much worse...
Within about 200 miles of the repair, the rattle returned with a vengeance. I had a hard time believing lifters would fail that fast, but it sure seemed like they had. I drove it for a few thousand miles on a couple of oil changes (by now I was running T6 10w30) to no avail.
Enter repair #2: I'd finally had enough, and after watching @cumminsturbofreak go through his saga, I decided I was going to switch to Hamilton's conversion kit. I spent an hour or so on the phone with Zach at Hamilton to learn more about the kit, and since I'm fortunate enough to be right down the road from Geno's Garage, I took it to Brennan and Dustin at Ram Diesel Specialist at Geno's recommendation. These guys are the next best thing to sliced bread. Not only did the install the conversion, but they uncovered why the valve train had failed so spectacularly a second time: the idiot dealer installed a trunion upside down. We're still perplexed at how someone could even do that without noticing. This in turn caused the cam to wobble in the bearings, which also had to be replaced. Engine came out a second time...
Here we are now - I'm a thousand miles down the road on this overhaul, and I couldn't be happier. The truck sounds like a fourth gen, no rattles, and the throttle response is quite improved.
Here's a
tribute video the shop put together to show everything coming apart and back together.
