Replacing battery
kvp
Hello all,
This modern 2022 Ram 3500 has so many electronics compared to my 1997 2500 I'm wondering if I need to do anything to keep power to systems when changing the battery.
Gas or diesel?
Diesel has 2 and you can swap one at a time if you're careful AF, though the IBS might get mad and take longer to settle.
Worst case, loss of power can cause apps a while to return to function on the radio.
Gas or diesel?
gas, I somehow and to this day don't know how killed the battery a couple years ago. After jumping I found several things inop till I'd driven awhile. Hence my question.
Whatever goes haywire will come back to life in a day or less if you disconnect with no backup source. So either way you will be fine.
Sometimes it’s almost better to let the truck sit disconnected for a bit(30 mins or so) than to try to hurry and get a new battery back in and connected. It can be nerve racking with all the electronics our vehicles have these days.
I replaced my battery last year and didn't do anything different than if I were replacing one in older cars with zero electronics. No problem at all with anything; presets, etc.
The only difference is removing the block of connectors attached to the +post, but that's not difficult to do at all.
I assume the 3500 is same as the 2500 as far as battery removal.
  • Like
Reactions: kvp
I just replaced both my batteries and no issues what so ever with presets or anything else.
Disconnect the negative cables on both batteries, driver side first, then passenger side. Wait 30-40 minutes. Then disconnect both positive cables. This allows systems to go into power-out/reset mode and the batteries can be changed out without issues.
Others will say "I didn't do that and I had no issues," and that's probably so. But it's currently the recommended way to proceed in order to decrease the chances of having problems.
One battery, gasser. Still apply?
The instructions were for diesels, but I don't see why they wouldn't apply to gas engine trucks as well.
