Will this work on 2023 tradesmen? What all needs to be done. Just alpaobd?Just throwing out a reliable fob alternative, I’m 15 for 15 on successfully programming these:
Pardon Our Interruption...
www.ebay.com
www.ebay.com
jscan is easier for beginners on the fob programming.
How do you use jscan to program the fob? Want to add remote start but not pay the dealer $80 to program the key.Worth the price of admission.
Jscan: $22.99*
Two 5-button ebay FOB: $51
Having extra spares and not getting raped by the dealer: Priceless
* (I had a 1$ credit)
Just successfully programmed the key suggested by Jimmy07 in my 22 3500 using jscan. Now just need to add the resistor and enable the remote start.
You were able to program a new Key Fob to your 2022 RAM 3500 ?? And it works ?? I thought anything 2019 or later had to be done at the dealer ... even JSCAN documentation says it can't do anything later than 2018. Did they come out with a new version that can do it ?
Yeah it pulled the pin and programed the key.You were able to program a new Key Fob to your 2022 RAM 3500 ?? And it works ?? I thought anything 2019 or later had to be done at the dealer ... even JSCAN documentation says it can't do anything later than 2018. Did they come out with a new version that can do it ?
Did you look to see if your hoodlatch has the switch or not? My 2020 Tradesman had it already installed.Just successfully programmed the key suggested by Jimmy07 in my 22 3500 using jscan. Now just need to add the resistor and enable the remote start.
No hood latch switch on mine.Did you look to see if your hoodlatch has the switch or not? My 2020 Tradesman had it already installed.
Found the connector KOSTAL 32124734123000-L but can't find them instock or without requiring me to purchase way more than I would ever need. Does anyone have any they would be willing to part with?One more question. What terminal connector are you using to add the wire to the factory plug. I did see 20awg is fine for the wire but didn't see what type of connector is used. I want to make sure I have everything before I tear it apart.
Does the wattage matter? I see 1 ohm .25 watt, .5 watt, 2 watt, etc.I just bought a simple 1 ohm resistor like this .. and soldered it inline to a wire that I used to ground the hood sensor circuit ...
