Regens at alarming rate!
When you do this, you cap the boost tube at the turbo and cap the boost tube on the other side where it hooks to the intake. Then pressurize the boost tubes and the intercooler. It will never make pressure going through the turbo. And the CCV being connected to the turbo just puts all of air you put in, go into the crankcase. Hope you didn’t blow some seals out.
In the parts diagram @CaptainMike posted, you want to cap it at #16 and #17 and see if it will hold pressure. If not then break out the soapy water to locate the leak.
I would not put more than 20-30 pounds of air to it and then with that regulated and going through a dryer.
How do you an intake leak post boost tube?
I'll drop by next week and confirm. What you're saying makes sense because something similar happened to my wife's old Ford Excursion with a 6.0.
The 6.0 always passed a ton of oil through the intercooler system, the blue intercooler boots didn’t like that. I’ve replaced a couple. Also the early 6.0s with the plastic piping on top of the motor split a lot, it got changed after a year or 2 of production.
Over the years I have done dozens of boost leak checks on turbo charged gasoline cars and have always hooked up directly to the turbo inlet and pressurized the entire system. Yes, you will have air going air through the crank case but you should easily be able to maintain 15-20 psi through the system which is more than enough to identify any leaks. Your method would certainly isolate the air to charge pipes and the intercooler ONLY but I don't think its 100% necessary.
Once you dropped about $15K in deletes, updates, and upgrades that 6.0 was a sweet engine!
After reading all of this (again) I haven’t seen anyone mention the percentage of EGR. If the percentage of EGR were too high, wouldn’t that lower EGT’s in the combustion chamber and exhaust system reducing passive regeneration ? Wouldn’t that be the reason passive regeneration only happens when towing or having to be run 75+ mph ? I know towing and higher boost reduces the amount of EGR. Maybe some with the extra monitors that are having problems and some that are not could compare the readings they are getting and see if there is a difference. I’m not currently having any issues but my truck doesn’t seem to be using much DEF and wondering if it’s because of increased amount of EGR.
Well crap, my truck did a regen after 5 engine hours, reset to zero and then quickly jumped to about 10%. Most of my driving is at highway speeds with very little in-town driving. I will say it is an improvement over the 2 +/- engine hour regens, but something still isn't right. The dealer tech is going to start a Star case and we'll see where that goes. Words can't express how utterly disappointed I am with this very expensive POS truck.
Ok, I'm not sure what all of this means, but thought I would pass along the info and maybe someone smarter than me can make it make sense. My truck, 2022 tradesman has been doing frequent active regens, approximately 3 per tank of fuel since new. It has never done a passive regen even when hauling a heavy load for an extended period of time. The last 2 tanks of diesel I purchased from a different station that advertises the fuel is up to 20% biodiesel. The first time I purchased it was by mistake, but I noticed something. For the first time, the truck did a passive regen while driving and my dpf filter went from 30% to 0 without the truck going into active regen. Since that time, the dpf filter has stayed on 0, even though the last tank and a half has been all in town driving. The fuel being used now is produced by a small time local refinery that buys soybeans from local farmers and uses it to produce the biodiesel blend. I have read that biodiesel is not the best for these trucks even though it is approved for use by cummins. But, why is it making my frequent regen issue go away? Just for information purposes, the local refinery producing the fuel is Continental Refining Company, and the call it Ultraburn F20 Blend.
Interesting. I'm no expert but have also been able to notice differences in miles between regens when experimenting with fuel. Was going 120 miles between regens, then 60 miles to regen on Wawa fuel. Switched to Shell and simultaneously started adding 12oz of Power Service Diesel Klean at fill up and was getting 275 miles between regens and only 30 miles to regen DPF. Just reduced the amount of Diesel Klean to 6oz per tank and mileage suffered, 180 miles between regens and 50 miles to regen filter. Driving style is very consistent. 130 miles a day Mon-Fri, mostly highway, no load.
I have stayed away from biodiesel but crap, might as well give it a try! I'm certainly not keeping this truck past the 100k warranty. Long term reliability because of fuel dilution has me very concerned.
We have a local Pilot station that has B20, it's worth a shot. Thanks for sharing.
My issue seems to be solved, must have gotten a bad air filter replaced it again and the now I’m back to 24 hr scheduled regens only.
Just an update since my last, my last two regens have been timed (24 hr regens), the DPF gauge was barely above 5% if at all. Air filter so far was the winner.
This is where the CTS3 has come in handy, it‘s Regen status shows Soot level or Time to next Regen. Had me confused at first when it got close to 80% and my DPF gauge showed zero on the EVIC.
Now I need to figure out how to get the CTS3 to show the same gauge as the EVIC as well (Soot Level).
Which air filter did you use previously and which one are you using now?
@RamCares I hope all is well with the team.
I own a 2022 3500 6.7 CC SB picked it up last Dec 4. Amazing ride, comfortable, quiet, and decent fuel milage, believe it or not 24 mpg for a trip from Va to Fl and back to Va.....other shoe drops. Three weeks ago, my DPF climbed rapidly 0% to approximate 32% in a day. The next day July 2nd it went to approximately 45% and then the regen started, within minutes the DPF showed 100%, CEL, reduced power, see dealer. So within one hour I am at the dealer. Can't help you need appointment. Scheduled appointment for July 8 @ 0900. At appointment, mileage 12,255 when checked for appointment, diesel tech takes truck, does a computer reset/forced regen to see if it would clear the CEL (3 codes were showing, don't recall what they were). An approximate 45 minute forced regen was done, no codes, no CEL...cool. Tech takes truck for a drive (about 25 miles round trip), when he gets back truck is doing an auto regen...second regen now in three hours. I drive home truck finishes regen during drive. July 12, auto regen. July 16 auto regen, July 21 (TODAY mileage 12, 693) auto regen. My DPF goes from reading 0% to 45% approximately in less than 50 miles before every regen. Dealer says there are no TSB's, recalls, notices, holy F's, or anything. Five regens, including the manual at the dealer in less than 500 miles. I believe it is a bad sensor. Dealer noted that there was a similar issue with the ECO Diesel, and it was resolved. BTW, mine was the first 22 at this particular dealer for this issue, they had seen it in older units.
Any info besides...there is nothing, will be accepted.
Thanks for your time.
Randy
3C63R3EL5NG121141
I have been watching this thread with some interest. Maybe I'm worrying about nothing, just seems like the '22s have some ... issues in this area my 2020 did not seem to have. (I have a 2022 HO). Close to 10k miles, I've done several empty trips and pull a ~15k 5th wheel. (I really need to run it over the scales). Anyway, I don't have another vehicle and don't really want one, so it's a daily to run around town and do errands when I need to, before someone tells me I shouldn't use it for a grocery getter. :eek: I don't like to do the short trips, but that's my situation. Having another vehicle around really isn't feasible, though I'd love to find something sporty, the appropriations committee (i.e. my wife, will not approve the expenditure, lol) I haven't gotten any codes, but I did recently get a pair of Banks iDash monitors and I love the visibility. I need to start some data logging, but I haven't gotten around to it yet.
I monitor the miles between regen PID, there's a DPF % PID (can't remember exactly the name), when it goes to 100% regen kicks in. It's no surprise when I have several short trips around town without pulling the camper, my miles between regen drops to around 320. Pulling/empty and highway speeds I never see much in the way of regens except the ones that are time-based.
An observation/theory I'm forming is the conventional wisdom around locking out 5th/6th gears when going around town is actually not as helpful one might think. Volume of air going through the system isn't has helpful as higher temps. Watching EGT1/3, the temps are a lot higher if I let it drop into 5/6th gear and lug a bit. I did some research and it's basically air volume -- more air at higher RPMs actually cools things down and higher temps should, in theory, help passively regen/clean. Far as I can tell, my DPF is currently 'clear', the % 'full' PID was at 17% when I got back from a trip this morning. I pulled the trailer this weekend and it did an active regen right when I hitched up. I'll see if I can add some more data on a truck that's ostensibly working (mine :cool: )the way it's supposed to, although 3xx miles between regens kinda sucks IMO. Not as bad as what you're seeing, but not great.
22 Ram! Mine went about 5 or 6 thousand miles before the first regen code. Now I get a regen about every 100 miles.
At the dealership they inspected it and I was told that there were a bunch of 22s that Ram didn’t install the filter or some part of the DPF system! I have to drive about 30 miles In regen mode every time, it’s getting really old and really expensive! Ugh!!!!
I feel like a broken record…
The part that wasn’t installed on 2022’s (and some late production 2021’s) was the particulate matter sensor. Its function is to monitor your exhaust at the outlet of the emissions system and check for signs of soot exiting the aftertreatment system. It does not control regeneration cycles or have anything to do with how your truck regenerates. It also doesn’t have anything to do with DEF consumption or dosing quantities. It’s simply a watchdog to make sure the DPF is capturing soot. If the sensor picks up too much soot in the exhaust flow after the emissions system, that would indicate there’s a breach in the DPF (cracked media or cracked pressure vessel) and would indicate that the DPF has failed and needs replaced.
If you’re regenerating frequently you have other issues. The Y43 recall and the PM sensor has nothing to do with it.
First thing to check is your engine air filter. Make sure you’re using the correct one.
Waited a little bit before responding to this thread so I thought I'd share my thoughts.
Previously I owned a 2021 Ram 2500 with the SO, of course, that I bought new. It was a daily driver and tower. It lived in Tennessee and would complete my daily commute of 20 miles. It only ever performed a regen at the 24 engine hour intervals.
I recently upgrade to a 2022 Ram 3500 with the HO. I got orders out to California and this new truck was used to pull a 40ft trailer across the country. During that drive I had zero noted regenerations, over 2000 miles, just a lot of DEF usage. Now that I am out on the west coast my commute with this truck, when I drive it, is 120 miles a day. I have added the banks iDash to monitor miles between regeneration and I am currently averaging 414 miles between.
This doesn't seem to bad compared to others but it is definitely happening more often than my 21. My 22 is missing the one sensor from the DPF filter.
Personally I believe the HO's are tuned and ran so much more differently than the SO that when you run around unloaded they really don't like it. Compound that with the fact that these filters do have life expectancy and its a recipe for future issues as the miles climb.
To help slow the issues I might have by dallying the truck I have a Jeep 4xE that I now drive most of the time when I don't need to pull the trailer.
There’s a bunch of 22s that they skipped some DPF part on, it’s BS
Like I said , yes Ram skipped some parts on the 22s! I use the factory air filter!
I’ve never been a litigious person, but if there’s a class action lawsuit I’m all in!
There’s nothing to go into a lawsuit over. There’s a recall and they’re working to install the sensor under the Y43 recall. It doesn’t have any impact on your frequency of regeneration anyway.
The regen frequency issue can be a whole host of different things (or combinations of things). It’s becoming more and more common, but the reason for it seems to jump around. Lots of different components can contribute to the cause of the problem. Step one is getting a knowledgeable dealer to diagnose it.
