LED light in tailgate handle
Does the new tailgate jumper harness go all the way to the chassis harness connector, like the arrow is pointing to in the pic, or does it only go to the tailgate/body transition plate?
this is where it ends and is identified as the old wiring tailgate harness
here it is connected and everything works fine the blue connector is the one for the new auxiliary light waiting to be ship
I'm not the only one confused by that image?
index.php
None of that looks like a 2019-2021 HD ram tailgate plate connector. Is that off of a 1500?
my truck is a 1500 and the parts i took were for a 1500 from a 2022 laramie or lone star this is the tailgate wiring i had and the new one is the same only with the new connector
What is the part number of the new tailgate wiring that you got? Because whatever it is, it won’t work out at all for the HD Ram owners (this is the HD Ram forum, so that would be pretty much most people interested in this).
¿Cuál es el número de pieza del nuevo cableado del portón trasero que tienes? Porque sea lo que sea, no funcionará en absoluto para los propietarios de HD Ram (este es el foro de HD Ram, por lo que la mayoría de las personas estarían interesadas en esto).
68531010ab
Nope.
1500:
Groan. I had a feeling.
@Thegame
You get the prize for confusing the most people ever in a thread by posting about parts to fit a 1500 on an HD forum and not disclosing that detail until pressed.
@Thegame
lol sorry but this is where I started looking for the auxiliary light so I have to move to 1500
my auxiliary lamp is on its way and I want to see if it will be plung and play for the 1500
Mine finally arrived today, but @Jimmy07 has already discovered the circuit just isn't there for it on pre 2022 trucks. Gonna have to tap it into the reverse lights or the bed lights.
Mine finally arrived today, but Jimmy07 has already discovered the circuit just isn't there for it on pre 2022 trucks. Gonna have to tap it into the reverse lights or the bed lights.
Post a pic please!
My plan is to tap it into one of the led bed lights.
Just waiting to order the light and handle once someone posts on here that it’s do-able.
Post a pic please!
I'll post pics of everything when i get home from work.
sorry goofy but do you know who could make me the harness for the Uconnect 5 that you have
check out this post ;)
Thanks for posting, I ordered a PW7 paint matched handle about 4 months ago and it finally showed up today. Unfortunately I too discovered it didn't come with the light. I ordered both the tailgate harness and the frame harness, at the same time and I received those two weeks later. I'll need to order that lamp tomorrow. I might just tap into the bed lights if the harness doesn't work out. Did the light come with the mounting screws?
Today I received the auxiliary light and connected it but it only works when I open the tailgate it does not turn on in reverse or when the bed lights are on
