Jgouldski
Anyone have any part numbers for the console wiring harness? The one that runs from the dash to the back of the console. It looks like there's 100 different versions of it. TIA
This got me thinking... I was trying to figure out a good way to add ventilated seats to my rear seats. This has given me a little more hope. Originally I was considering putting the front seat bags and blowers on the rear seats then doing some custom wiring with a switch near the rear heated seats switches to enable this, or maybe adding a switch to the rear heated seats wiring to be able to switch the same circuit to send the power to the heating elements or blowers. Kind of just fizzled out with the brainstorming.It didn’t get added. The two extra spots are for the ventilated seats buttons on a 1500, since they share those parts.
The wiring is the easy part. The 2500 rear comfort module doesn’t have ventilation capability, and won’t recognize the 1500 rear comfort module messages.Would it be a massive PITA to add the 1500 wiring to this to achieve it? Or Frankenstein the 2 somehow?
Would it cause too many issues to add a switch to the heating circuit to send power to a ventilation blower instead? Possibly even use the ventilated seats buttons from the 1500?The wiring is the easy part. The 2500 rear comfort module doesn’t have ventilation capability, and won’t recognize the 1500 rear comfort module messages.
Did you find the part number for the harness to power usb/110?For anyone with a center console that's looking to just add the rear USB/110v plugs and heated seat buttons, comparing the picture in Post 73 to my original console end cap pictured below you can see what you'll need to change. You'll need to replace the center trim piece with the one that has the spots for all of it, and you'll also need the appropriate wiring. I'm likely going the route of replacing the center console harness so I have all the OEM wires and connectors. I'll add part numbers once I have them.
Do you happen to know the part number for the jumper harness?The wiring harness from the dash to under the drivers seat, that's the jumpseat harness.
In OEM Center console trucks, they came with a 12" jumper harness from the console to the dash plug.
Haven't tackled this project yet, but will update when I have.Did you find the part number for the harness to power usb/110?
If noone else chimes in, I can take a look at mine next time I have my console slid back or when I do finally tackle this.Do you happen to know the part number for the jumper harness?
| Quantity | Item Description | Part Number |
| 1 | Console Bracket Front | 68291157AC |
| 1 | Console Bracket Rear | 68366628AA |
| 2 | Screw - Front Bracket To Dash | 6505069AA |
| 2 | Hex Head Bolt w/ Washer - Rear Bracket To Floor | 6104386AA |
| 4 | Hex Head Bolt w/ Washer - Console to Brackets | 6508182AA |
| 2 | Snap-in Nut (Front Bracket) | 6511163AA |
| 1 | Instrument Panel Closeout Panel, Right | 6QB50TX7AA |
| 1 | Instrument Panel Closeout Panel, Left | 6QY39TX7AA |
