DIY: Add Aux Switches to 19+ Ram 2500 Laramie 6.7L
Do NOT get a bypass cable/brick that connects directly to the SGM behind the cluster. Major PITA.
If the KAoDTECH cables are OOS, reach out to Jimmy07 here. If he has parts and bandwidth, he can hook you up.
Thre's only one setting to enable AUX switch bank.
Link takes you to POST #1 in this thread. Read the posts Florotory went to a lot a time and effort to make for the benefit of everyone.
Got it, thank you. I purchased the harness kit from Florotory, it made the wiring part way easier...
@Florotory I am in Aus, and have a 2022 6.7L 2500. Id love to undertake the AUX panel upgrade.
You seem to be the man with the solution from all the threads I have read.
I previously had a 1500 and that was easy, I just purchased the kit and had it installed.
The 2500 looks like I need to buy the separate pieces and build it myself?
I can see the part for the switchpanel I need is 68596339AA.
Not sure what else I need and what you can supply via international postage? Am I correct in assuming the 6.7L already has the AUX PDC? If that is the case, is is just the loom I need from you and the switch panel from an online mopar store?
Cheers.
Cheers.
Yes, you should already have the AUX PDC (unless the Australian models are different).
If you look at the first page or 2 of this thread there should be a list of what’s needed for the harness and terminals for inside the PDC. Not sure if you have sources for the terminals down under or not.
I’ll send you a PM.
I’ll send you a PM.
Appreciate the prompt reply! Greatly appreciated!
Ill await your message.
does anyone have the part # for the AUX PDC? Don’t need the wiring just the PDC.
The aux PDC is an integrated part of the left dash harness, and simply can not be bought separately from a mopar parts supplier.
Thanks for this article, especially Florotory and Jimmy07. I have a 21 2500 6.7 diesel with an 8.4 screen. I need an aux sw with exhaust brake, tow/haul, front park assist, rear park assist. I cannot find one. I checked the pn's earlier in this thread. They don't appear to have tow/haul. I don't (I think I don't) have a tow haul button/icon anywhere but on the switches that would be replaced with the new switch bank that has the aux sw's. Any info or help?
I mean when I look them up. They list the exhaust brake and front/rear park assist. Just order by the pn's listed here?
Did you look here?
They all have tow/haul.
Tow/haul, exhaust brake, front and rear park assist:
19-21: 68476031AA (now replaced by 2022 part number)
22+: 68578994AA
I was finally able to get all the parts needed to make the bypass cable as well since they tend to be out of stock. Ill add the diagram to one of the posts in the DIY section of this thread.
If anyone wants me to just build one for them just send me a DM.
Got a question about the signal wires in the plug behind the switches. Witch pin is for witch aux button, didn't see if you stated that when building the harness.
In order on the schematic. Aux 1-6 is 3 thru 13. 8,6 and 7 are the wires that go to the factory harness
1st Ram truck (2019 3500 Big Horn). Interested in adding the aux switches to my truck and have ordered the switch panel from TascaParts (per spreadsheet - 68376642AE but superseded to 68596338AA). Posted question yesterday about this because tow/haul and exhaust brake where in different order but was helped out on that, thank you @jsalbre. I was going to purchase the bypass cable from Infotainment but @Florotory if you have the bypass cable and complete harness kit for sale I would rather support a member and purchase everything from you. I'm leaning to the Windows version of AlphaOBD and actually read somewhere this is the preferred method.
I personally prefer the windows method but I do have both in case I’m traveling a need it but don’t have my laptop. Plus it’s not very expensive to buy both versions. I just went and found an android phone/tablet that was on clearance.
Very good point.
