The Aux Switches basically gives all of your accessories a central switching panel with an OEM look and location instead of mounting a bunch of aftermarket's switches all over your truck!
The aux switches are a set of switches (pictured) that can be wired to any accessory that you choose, through the PDC. For example you can add fog lights, reverse lights, a CB radio, a winch etc. You pick the accessories that you want to control and match them to the correct fuse and control them all through the Aux switch panel, the outputs are in the gray and black plugs mounted to the PDC in the engine compartment.
I have an HD Ram with the Cummins Diesel. Ram includes the Power Distribution Center aka PDC, however I had to add the 6 Switch Aux Panel. After that you will need to make a harness (or buy florotory’s custom harness-Highly recommended!) to control the relays and fuses you install in the PDC. You can also program the aux switches as momentary or latching switches and also program them to remember their last state, so that they remain on if they were last turned on etc.
Hopefully this helps.
