thats brutal! I use 2.5 gallons every 1800 miles or so unloadedOn a recent trip to Dallas with my 2019 3500 HO I consumed just a little over half a tank of DEF one way (1300 miles) towing 12,000 lbs. Not towing I am maybe a gallon every 100 miles or so...I miss my deleted 2017 for this very reason haha.
I made a typo n the unloaded use - probaly 800 miles to a gallon of DEF - so about what yours is I guess. But towing sucks up the DEF.thats brutal! I use 2.5 gallons every 1800 miles or so unloaded
Makes more sence lolI made a typo n the unloaded use - probaly 800 miles to a gallon of DEF - so about what yours is I guess. But towing sucks up the DEF.
I've never found the DEF gauge to be very accurate. If it came off from full quickly, it wasn't "Full". If it's truly full, the needle sticks there for a while.So does this sound right? 2020 Ram 2500, completely stock. Just purchased and wanted to take a road trip. DEF was full when I left, drove ~450 miles and am down to 3/4 tank (unsure of total DEF capacity...gonna look up).
Tank should be 5 gallons. If not really full, it will come off the full mark quickly. When I fill at the pump, it will stay on full for a while, then drop quickly. on my 250, and now my 3500, at 1/2 tank indicated I usually cannot get a full 2.5 gallons in to the DEF tank.So does this sound right? 2020 Ram 2500, completely stock. Just purchased and wanted to take a road trip. DEF was full when I left, drove ~450 miles and am down to 3/4 tank (unsure of total DEF capacity...gonna look up).
I know this is a broad question with several different variables, but do you go through over 1/4 tank of def fluid for roughly 500 highway miles? I see guys quoting mileage in the "thousands". Just trying to estimate other drivers DEF consumption experiencesTank should be 5 gallons. If not really full, it will come off the full mark quickly. When I fill at the pump, it will stay on full for a while, then drop quickly. on my 250, and now my 3500, at 1/2 tank indicated I usually cannot get a full 2.5 gallons in to the DEF tank.
hard to estimate just like fuel millage... everyone will have their own millage based on their driving habits.... my brother has one of my old cummins trucks i could get 19mpg out of it he can only get 16mpg nothing has changed with the truck i can still get 19mpg out of it... same goes with DEF MPGI know this is a broad question with several different variables, but do you go through over 1/4 tank of def fluid for roughly 500 highway miles? I see guys quoting mileage in the "thousands". Just trying to estimate other drivers DEF consumption experiences
The truck computer had me at 19 and some changeNope. When I pull my 12k 33 ft 5th wheel 1000 miles I will only use 4 gallons of DEF. When I fill up and do not tow I wonder if the gauge is working because so much time passes between DEF fill ups. What MPG do you get in that 500 miles?
"DEF consumption will be approximately 2% of the diesel fuel consumed. (For every 50 gallons of diesel fuel burned, you will use 1 gallon of DEF)"
I have a 2019 3500. I am using 1 gallon of DEF every 300-400 miles.Has anyone still having there DEF run out quickly after the emissions update? I put roughly 1600 miles a month on my 2019 ram 2500 6.7L and fill up the DEF once a month as well. I have not towed with the truck since last fall. Am I just stuck with this issue or is it possible that the update was not done.
Last three posts are:Still on first jug, just over 20000 km with 1/2 tank still on gauge
