Crusty old shellback
No green detectedOk, got the print out. But it's not what I saw on the machine.
It shows total toe at .2
And steer ahead toe at -.02.View attachment 75715
That looks awesome manSo I mounted the backing plate, then used a new sharp razor to cut out the center hole. Went easier than I thought.
View attachment 75817View attachment 75818
Used some lock time on the screws and mounted the front plate with the backer plate on the inside. Wasn't that hard to get the washers and nuts on the backside. Just the roof was hot and kept burning me.
Wired up the switches and mounted them.
Factory optioned off road lights.
Hooked up the last couple of wires to the battery, installed the fuses, and we have lights.
Thanks. I was so nervous cutting into the overhead. But I think it came out fine. Best, most conventional place I could find to mount the switches. This was the most nerve racking of the whole install.That looks awesome man
If you want to get all those rockers matching check out these people. They make custom ones, serious ones, silly ones etc
High quality OTRATTW Contura V laser-etched rockers
OTRATTW Contura V laser etched rockers are compatible with all Carling Technologies V-Series switches, including sPOD, Daystar, and Painless Performancewww.otrattw.net
I didn't want to spend that much money. But it can be done.I would like to do the same thing but mount a switch pros or s-pod in that location.
I am impressed. Question. Have you or anyone considered using cat5 or 6 wires for the switches to the relays. A single run with 4 pairs in each so eight wires. Up to 4 switches. I would think they could handle the voltage and be smaller and easier to run. Or am I missing something?I didn't want to spend that much money. But it can be done.
I have about $800 total or less. That's lights, switches, relays, power block, wiring, black bolts, connectors, paint.
I'm not counting my time in there.
