Ok, after 2 days at the tire shop, here's the final results.
Alingment:
Had a little toe in. Worked best we coukd and wound up with .07 toe out. Tech told me he had been trying for 2 years to get them to have the machine calibrated. Every time he turned the wheel then went back to center, he'd get a different reading. It shouldn't have changed. So this was the best he could do. Close to Thuren specs. I'll be keeping an eye on tire wear.
Balance:
So first thing I had them do was pull a tire and put it on the balancer just to see if it would balance with the beads. I've seen where it worked, I've often hears it wont work.
Well I don't think it worked.
So had them pull out the beads and got it to balance. Almost 5 ounces on 2 of the tires. A little high.
But the other 2 tires, one took 9 and the other 12 ounces, way too much. And probably the reason I had vibrations. I used 6 ounces bags of beads in each tire. Also one bag did not fully open.
But in the end, almost all of the vibration is gone. Just a little bit around 70MPH.
Also noticed that the tires have a high pitched whine to them.
I contacted the seller to see if I can 2 replacement tires? Or a full refund and I'll go get some AT4W or KO2 or 3s.
