NHOverland
If you are running the twin compressor, you only need the purple wire from the three pin plug on the compressor side. Hook the purple wire to an output on the Switch-Pros. Power and ground direct wire to the battery.Any of you guys with the ARB and the Switch Pros use the Switch Pros quick connect harness for the ARB? I've got one coming with all of my SDHQ stuff and was wondering how it fit into to everything. I also plan to pair down the ARB wire harness as I don't need the lockers either.
