@el_barto you've had this set up for a while now. Are you happy with the compressors performance without a tank? Would you add or change anything?
Have the push fittings been reliable? What size is that air line and do you feel like it moves air well enough?
I ordered the same compressor and two of the ARB couplers with covers yesterday. Need to source a few more parts.
Haven’t had any issues with the push fittings, other than being difficult to disconnect (when I changed rear bumpers). I used 3/8” OD (1/4” ID) Nylon DOT tubing.
I feel like it moves air fine, but I’m not using air tools, just airing up. Seems to air up as fast or faster than other peoples compressors, but variables are tire size, air-down pressures, and air-up pressures. Obviously not as fast as a power tank. I save time not having to pull the compressor out, connect it to the battery, etc.
I considered a tank but I don’t think it would really benefit my use…. a tank isn’t going to be enough for all the tires so once you empty the tank (probably before the first tire is filled) the compressor will be doing all the work. If I had airbags or an air horn, a tank might be valuable.
I have been looking to add an adjustable mechanical regulator inline , so I can just let it rip and then cutoff once the target tire pressure is hit.
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
