AlfaOBD
That’s going to be a tricky one. You would first need 12” radio with software 20.29.13. There’s a few of us actively working at this, and one of us got a new radio module with the new software, but there’s more involved than just enabling the off road pages. First off, the pages seem to be tied to Sirius guardian, so you can’t have guardian, otherwise they won’t push the pages app to your radio because in their eyes, your VIN doesn’t support it. Second, the theory is, once guardian is cancelled, the radio module will have to be installed into a 2021 truck that currently has off road pages, so the app can be forced onto your radio module, then reinstalled in your truck. Then, if that even works, it’s questionable whether or not the BCM firmware will support the off road pages, and broadcast the truck info to them.
wow that is way too much work, especially since sirius gaurdian is more important to me than the off road pages. Thanks for input. Hopefully you can get it to work though.\
Is the forward facing trail cam still hit or miss? aside from tire grid lines does it offer anything else over the regular forward facing camera?
@Brutal_HO
I ran across your thread. Can you tell me your settings in AlphaOBD?
I think these are the ones you might need.
CBC Features:
DRL Configuration: Optional DRL
DRL Lamp Location: Dedicated
DRL Dropout Enabled: No
LED Dedicated DRL Present: Yes
Daytime running lights CSM Present: Yes
Signature Light Present: Yes
Not sure on these,
Right Dedicated DRL Lamp/Right Signature LED Present/Right Front Turn Signal #2/Headlamp Leveling Output Present: Yes
Left Dedicated DRL Lamps/ Left Front Turn Signal #2/Left Signature LED Present : Yes
CBC Features:
Not sure on these,
CBC Features:
Not sure on these,
Awesome.. Thank you so much.
Scott
My paltry 31 gallon Hemi fuel tank tells me it's empty with no range remaining and yet when I go to fill it up, it will only take 27-28 gallons which means my bladder has more range than my truck and that's not a good thing at my age. I saw that there was a fuel tank calibration on AlfaODB and I got all excited thinking I could actually take advantage of all of my paltry 31 gallons. But when I went into the settings, it didn't look like there was anything that could be done. My fuel capacity was already correctly set to 117 liters. There was no setting for Cluster-Fuel Tank 1 Calibration, Full; which I don't really care about. The settings for Empty and LFW were set to 2% and 8% respectively and those were the minimum settings that those variables could be set to.
Has anybody played around with this? I'm thinking I could fool it by increasing the fuel capacity variable. Is there any reason not to try that?
After installing a 50-gallon diesel tank, I was able to update the DTE after changing liters to gallons. Worked like a charm.
Can you tell me what you changed to the DTE corrected? Would you have a screen shot you can send me?
To follow up on my previous post: So I decided to try to increase my fuel capacity to see what it would do. I figured a setting of 130 liters should make it accurate. When I set it to that, my range went crazy high. I started trying different capacities until I found that everything went as expected up to 123 liters where I showed a range of 225 miles. If I bumped it up 1 liter from there to 124 liters, my range would go from 225 miles to 450 miles. For how much fuel I had in my tank, I wanted my range to show about 260 miles. I'm at a loss as to what's going on. I decided to leave it at 123 liters as that's still a little better than it was.
Got my alpha obd this weekend and been playing with it a bit.. I have searched this and other forums but cannot find the answers to the following question.
Can you perform a relearn procedure for the TPMS?
If not can you turn I off completely. Hate the EVIC being forced to that every time I turn it on...
If someone that has forward collision warning wants to give this a try, these should be the settings to get pedestrian emergency braking working.
VehConfig 8: Pedestrian Emergency Brake Present- YES
CustSetMenu 3: Pedestrian Emergency Brake CSM Present- YES
I set this and have completed several drive and sleep cycles without the options showing up in forward collision controls. Any advice?
Not sure what you mean by relearn, but you can adjust the threshold to a lower value (if you're getting prompted to air them up). Some folks have reported that this can be done via the uconnect screen without even using AlfaOBD, by simply turning on Tire Fill Assist, then deleting the current preset and creating a new one. I had already updated mine via AlfaOBD long before I heard of that, so can't personally confirm it.
I have a Tazer by Z auto as well.... I can force a relearn were the uconnect and the EVIC resets a couple times...
I'm getting prompted because it does not recognize the sensors in my aftermarket wheels. Not to sound righteous... but I am busy and don't have the time or energy to drop off at a dealer. I USE my truck daily. Just wondering if there was a relearn procedure within alpha or if I can turn the system off completely until I have time to deal with the primary issue?
TPMS can be disabled. See this thread for a link.
Thanks Pronto. Worked great!
Does anybody know if there is a setting to disable the speed lockout on the surround view camera? Mine turns off around 8mph and can't be selected again until speed is reduced. I'd like to be able to have it on at any speed.
Not possible.
The NAViKS aftermarket black box is the only known working solution. There a couple threads on it here.
@Brutal_HO ... Add me to the list for having a working front trail camera. It took 3 days for it to show up in Uconnect, but it popped in this morning.
Is there any way to get the passenger seat heater to come on with the drivers side during remote start?
Did you lose the overhead camera views during that time?
I can get the button and guidelines options to show, but they never did anything and I lost the overhead camera views. I drove it around like that for a couple days. 2 I think...
No way to change any of the seat heating options that anyone had found. Temp or passenger...
Sent from my work avoidance device
