Bigboom338
I assume that you will have a camera on the camper also?
Yes, but the only place I am at all concerned about is the underside of the heads on those big bolts. I can easily keep an eye on them and if needed add some insulating paste or something in there, or some extra never seize. All of the other stainless fasteners are so small in relation I don't think it'll be a problem - not like the truck will be submerged (I hope). The truck generally doesn't live outside permanently either.Just out of curiosity, have you considered potential galvanic corrosion issues with the aluminum and stainless fasteners?
Absolutely. That's the plan for the weekend, and it should be the last fabrication project before the first trip. But I can test fit it today and I want to do that first - it's been a 2.5 year project and 1.5 years of fabrication.. I need some payoff. And thanks!Are you planning on finishing the edges of the aluminum bed with flat bar or leave it open? That would drive my OCD nuts. Fabulous work by the way.
Tomorrow I clear the junk out from in front of the camper and we see if it fits.
Absolutely - I've been weighing it as I go at major milestones and will do the same when it's done, both with and without our very heavy camper. Thanks!Maybe weight your rig prior to installing the camper since you have the original weight of your rig? And maybe a final weight once everything has been installed. It would be very interesting to know exactly how much weight was added during different phases of construction. Happy trails!
Fillnecks installed. I won't rivet the surrounds in until I make the edge trim for the bed.
SnapPads installed. Put a full set on the truck and got one for the EQ systems tongue jack on our enclosed trailer as well. Looks to be a high quality product, easy install, should prevent me leaving divots in asphalt while camping.
Back down at ride height.
I probably will, but mainly for the front ones. They have different styles and attachment methods depending on the size of jack/pad. I can't see the rear ones ever coming off, they took a lot of force to get on. The front ones, if I dragged them, maybe...You might want to think about a backup securing system for those snap pads. Safety wire or something. I've seen more than a few posts of folks loosing them off RV's. Now maybe they're dragging them, but food for thought...
